Question about Dell P1110 21" CRT Monitor
Monitor goes into standby when RS232<>TTL cable connected
I am trying to fix my dell P1110's brightness problem using WINDAS software and a RS232<>TTL cable to lower the G2 value, but whenever I connect the cable to the four pin header on the back of the monitor the monitor screen goes blank and the green light turns amber. It's very frustrating, and I am hoping someone out there knows why this happens or how I can get around it.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Use original software for the device. Check to see if monitor is compatible with the motherboard
Posted on Nov 04, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: problem in monitor
you need to either buy a new inverter board, or if you are competant with soldering onto boards, you need to replace the c5707 transisters at points q740, q739, q760 and q759 on the larger board. best place really for the replacement c5707s is ebay
Posted on Aug 27, 2007
Anonymous
SOURCE: Monitor Goes Blank after 30 mins....
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Posted on Jan 29, 2008
Anonymous
SOURCE: Ultrascan P1110 to Bright....
Step by step fix
http://fyrskeppsvagen.com/tips/dell_monitor_p1110/index.html
Posted on May 17, 2008
Anonymous
  • 11 Answers
SOURCE: Screen goes blank
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
Buddy Mcsparrin
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
I am replacing the 10M resistor with a lower value but can't find a source. This is supposed to cure the brightness problem. Telectron was mentioned in one forum as having a kit comprised of 3 different...
If you cannot find a 10M ohm resistor you can connect lower value resistors in series so it totals to 10M (ie two 5M resistor in series equals 10M). The only thing you need to be careful is to make sure the wattage is the same or higher than the original resistor.
Jan 05, 2010 | Dell P1110 21" CRT Monitor
Model # 32A43 brightness problem
Check for about 100 to 500 volts on G2 pin (screen voltage) when screen control is adjusted,if less than 200 volts,remove the g2 capacitor(from G2 to ground) on crt board,if screen regains brightness,then replace capacitor,if ok ,troubleshoot the ABL circuit,look for an open or changed valued resistor,also check your heater voltage.Good luck.Cheers.
Nov 04, 2009 | Toshiba 32AF43 32" TV
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
My screen sayin signal cable disconected
if you are using an lcd monitor, make sure you have connected the vga (screen cable) properly and tight both on the tower and your monitor. if its crt monitor then make sure the vga cable is tightly connected to the tower on the female connector
Jul 19, 2009 | Dell UltraScan P1110 21" CRT Monitor
When i turn on my computer, it displays signal cable disconnect,and the restart switch doesnt function
try 2 check the cable if it is properly attached. try connect a different cable from your computer to your VGA
Jan 25, 2009 | Dell UltraScan P1110 21" CRT Monitor
Too Bright P1130
Dell P1130 Service Manual r + g + b resistors measure on them and chassis -ground by have a black picture for getting the highest voltages if its looks like out of range look the manual and the resistors on there values that the ones and values you write about can be made of the only few carbon composite resistors witch can have get some drift over time over the tolerance. this kind of dark brown resistors are very sensitive for moisture and more, best is to soldering one leg of the resistor out and measure for compare on every resistor its resist or disconnect the crt print from the tube and if the resistors are good then reduce on the potential meter on the line transformer some reduce brightness below if its so bright that its against the backlashes. control focusing also after that . i have only suggest by this chassis its a 25 years ago i was very busy with c r t t v and video and more a little study on the manual can give you other results for some deformed capacitors also why its come out of range begin with the power supply and don,t forget to disconnect before measuring the power supply the horizontal line load to the line transistor (fly back because of your multi meter and have a 100 w lamp in serial in mains to control for your power supply on .
Jun 17, 2017 | Dell P1130 21" CRT Monitor
Too Bright
It could.Check the screen voltage G2,If its high more then 400v this fix could work.
Samir
Mar 09, 2008 | Dell P1130 21" CRT Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
hi sounds like you have weak picture tubes do not open the screen ***DANGER OF ELECTROCUTION AND DEATH*** try taking to some1 who knows how 2 fix it good luck
Feb 22, 2006 | Dell UltraScan P1110 21" CRT Monitor
P1110 Blurry/dubble image
your beam needs calibration take it 2 a pro... windman
Jan 28, 2006 | Dell UltraScan P1110 21" CRT Monitor
Open Questions:
MOZILLA mail password reset #{18OO~8O31O69} phone number usa asif There are two circumstances that can cause someone to want to change his/her MOZILLA password: 1 forgetting the MOZILLA password and needing to recover it and 2 to change the MOZILLA password. The latter can be because the MOZILLA password has leaked to someone or the user wants to adhere to the good practice of changing his/her password periodically. It is a good practice to change one's MOZILLA password at least once in a month. Contact MOZILLA Mail Password Reset 1-8OO-8O3-IO69 . For your convenience to contact MOZILLA Mail Password Reset We have provided all possible information of MOZILLA Mail Password Reset. You can contact MOZILLA Mail Password Reset on the given phone number 1-8OO-8O3-IO69. Changing an MOZILLA Password The following steps show in detail how to change an MOZILLA password when the current password is known: Sign into the MOZILLA Mail Account from MOZILLA Do you want to recover/reset your MOZILLA email password? So you'll be do the some steps to recover your MOZILLA password. We'll help you to fix your problem and we'll guiding the some steps to recover your MOZILLA password. Follow and do the below steps to recover your MOZILLA email password- Go to the MOZILLA - login page. Enter your Username or Email address and click next. Click Forgot Password below the Password field. Enter your Email address and click Next. Verify your Email address or Phone Number and click on the Next. Open your Email account and check your MOZILLA mail message on your Gmail account. MOZILLA is an abbreviation for America Online, one of the country's earliest providers of internet and email services. While MOZILLA's dial-up internet is not as widely used as it once was, many people still use the company's email service. It's a great email service that lets you stay connected with your family and friends -- that is if you remember your password. Forgetting your password on any internet service is an annoying and sometimes painful process; thankfully, MOZILLA has made it easy to recover or reset your account's password. *Please Read* If you don't remember or didn't sign up with one your alternate email address, or you didn't use a mobile phone to register, you will not be able to reset your MOZILLA password. If you find yourself in this situation, create a new account. If you do have access to your alternate email or mobile number, follow the steps below to reset your MOZILLA password.
Oct 23, 2019 | Mozilla Computers & Internet
See all Dell P1110 21" CRT Monitor Questions
Computers & Internet Logo
95 people viewed this question
Ekse
Clive
Clive
Alun Cox
