Question about Frigidaire Affinity FAHE4044MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 14 Wash Cycles, 2 Specialty Cycles, 800 RPM Spin Speed, WaterFall Wash, Fresh Water Rinse and Energy Saver Option
I have a washing machine model Frigedaire FWAC16H3M3GKW (MADE IN CHINA) PNC: 913 April 00 05 wash Initially once the water level reached this indicates a fault F3: "the spin does not reach the alarm of the front cover." Solution of failure is "close lid" indicates the manual, but it closes continuous failure and other strange is that indicators (blue LED) Operating status who head rinse LED indicating lights steadily .
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
futureloginn
  • 734 Answers
SOURCE: water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
SOURCE: frigidiare washing machine squeaks in spin cycle
use fairy liquid it works best
Posted on Mar 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: Frigidaire FWS833AS1 - My washing machine recently
Hi
Thanks for using FixYa. The smell might be due to burning of lid switch. If the washer isn't spinning then it might be dueto a Lid switch or due to a bad motor coupler. You can check for the lid switch& replace it--
First unplug the washing machine. Then remove the two screws that hold the top consolein place; these are located in back of the main console (where the dials are).Once removed, the entire console swivels back, exposing the wiresunderneath.
After this unplug the wiring harness that is connected to the washing machinetop flat surface. Now remove the two s-shaped brackets with a screwdriver byprying underneath. This will allow you to remove the main sheet metal framearound the washing machine. The lid switch assembly is located under the topconsole. Now, remove it and replace with the new assembly and put it backtogether.
Please look this schematicfor lid switch location(part # 50)--
You can buy the lid switch from this link--
Frigidaire FWS833AS1 Lid switch/assembly
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 16, 2009
I have a defy laundromaid. The machine doesn't reach the correct water level to start the washing cycle. However if I deselect wash and rinse options it does spin
good solid commercial unit 13 kg
could be a timer or control board fault
my best guess is
faulty water level sensor
Sep 20, 2016 | Washing Machines
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
Its stops when it reaches in 39 minute the function set on cottons what is the problem
Try resetting the mainboard by removing the wall plug overnight. May also be a faulty lid switch if it is a top loader.
  • Hello, my washing machine stops completely when it reaches ... www.shopyourway.com > Manage My Life > Questions ... my washing machine stops completely when it reaches the pause cycle, ... Answered in 5 minutes ... Kenmore washing machine 417 44252500.
  • Washing machine stops mid cycle - White Goods Help www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help Possible causes when washing machine stops mid cycle by a repairman with 30 years experience.
  • What could cause my washing machine to stop before the ... diy.stackexchange.com/questions/21181/what-could-cause-my-washing... What could cause my washing machine to stop before the ... i.e. it never reaches the end of the cycle ... What would cause my washing machine to stop at the rinse ...
  • Washer Stops Mid Cycle - Repair Parts - RepairClinic.com www.repairclinic.com/...A-Washing-Machine/50---/Washer-stops-mid-cycle ... listed below for the symptom Washer stops mid cycle are ordered from most likely to least likely to occur. ... Electrolux Front Load Washing Machine Disassembly
  • once my washing machine reaches the rinse cycle, about 3 ... https://answers.yahoo.com/question/index?qid=20080526150940AA3izVT
    • RESOLVED
    • 6 POSTS
    • 5 TOTAL ANSWERS
    2008-05-26 · Once my washing machine reaches the rinse cycle, about 3 minutes after ... Once my washing machine reaches ... My washing machine stops after the ...
  • Common Problems to all Washing Machine Brands ' Washing www.appliancerepair.net/washing-machine-repair-2.html Washing machine designs vary widely, ... but stop agitating after a few minutes and fill some more. ... stop the spin cycle and unplug the washer.
  • My washing machine will not spin and now it does not stop ... www.shopyourway.com > Manage My Life > Questions My washing machine will not spin and now it does not stop when it reaches the water level. ... Answered in 5 minutes
  • washer stops in the middle of washing cycle - Appliance ... forum.appliancepartspros.com > ... > Washer Repair
    • 6 POSTS
    • FIRST POST: 2012-02-07
    2012-06-22 · Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer stops in the ... but when the timer reaches 24 minutes left to ... Washing Machine stops ...
  • LG Washer Stuck Timer 2 - YouTube Youtube
    • BY SBUBANDIT
    • 14 MIN
    • 4.9K VIEWS
    2012-08-29 · Video embedded · In this video the washer display shows 8 minutes remaining in ... machine stops and turns ... 10kg Top Load LG Washing Machine
  • http://www.bing.com/search?q=washing+machine+stops+when+it+reaches+39+minutes&qs=n&form=QBRE&pq=washing+machine+stops+when+it+reaches+39+minute&sc=0-47&sp=-1&sk=&cvid=04BC47135B524BD8B5BAC3759F010C1B
    Jun 10, 2016 | Washing Machines
    What is E1 codes for LG washing machine
    Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on.
    Aug 25, 2014 | LG Washing Machines
    My Kenmore 300 model # 11028332700 washing machine filled with water and stopped working. It won't agitate, spin or drain. I've replaced with lid switch and checked the coupling and it's fine. What's...
    Possible fault with the water level sensor , it must send signals to the program controller main board to switch on the motor for the wash cycle only when the water level set is reached. Remove the water level controller unit , check the diaphragm with a blow test , it must switch with vacuum , if not replace.
    Aug 22, 2013 | Kenmore Washing Machines
    My washing machine will start even the water level does not reached the dsesired level
    Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
    Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
    May 02, 2013 | Washing Machines
    Washing machine does NOT stop filling w/ water!
    If the m/c keeps filling, where is the water going ??? if the m/c doesnt reach the required water level it will not start, check the drain hose at the back, make sure its at least 24" above floor level, if it lower then it will just empty as quick as you fill it on gravity.
    Nov 19, 2009 | GE Washing Machines
    Washing machine drum rib broken
    I have done some wondrous jobs with a soldering iron and some other plastic material same as the job at hand. YOu can melt the sacrificial plastic as you apply the heat onto the receiving drum surface. Work it in well like you are puttying it. Then let it cool. Once set you can set to with a selection of Wet or Dry papers dipped in warm water which you then use to "Sand" the tub surface until it is fairly smooth again.
    This idea of course is only applicable if you just cant find a replacement or new tub.
    Oct 20, 2009 | Washing Machines
    Simpson esprit washing machine
    put a new pressure switch in it
    Mar 25, 2008 | Washing Machines
    Frigidaire Affinity FAHE4044MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 14 Wash Cycles, 2 Specialty Cycles, 800 RPM Spin Speed, WaterFall Wash, Fresh Water Rinse and Energy Saver Option Logo
    37 people viewed this question
    Top Frigidaire Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
