Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic PT-47WX53 G
I appears to be the conversion There is a bow at the bottom of screen and a lot of green/purple coloring. The writing on screen is double.
  • 2 more comments
  • metalman Nov 09, 2007
    double image with green and purple and bowing
    mine is bowed on top and bottom. is there a way to fix it
  • jimcain Nov 24, 2007
    I have a PT-53TW53 that has a green bow across the bottom. The other 2 colors are perfect. Is the green gun replaceable?
  • Anonymous Mar 21, 2008
    • I have a Panasonic Model #PT-47WXC43G.
    • 1st: I replaced the convergence IC's STK 392-110 due to a convergence problem.
    • 2nd: After the repairs, I attempted to turn on the TV and it tried to power up but turned itself off immediantly then the power light blinks 3 times every five seconds.
    • There is no sound or picture now.
    • I feel that I performed a good soldering job but anything could have happened.
    • Anyone know of something I may have done wrong or that I may have missed?
    • Has this happened to anyone else?
    Thanks for any help before i have to call a technician!
I replaced the ic's. The green bow is gone but now I cant converge the red to the right. Di I mis solder on of the ic pins or could it be something else?
Posted on Jan 24, 2008
    Problem Solver:
  • 19 Answers
My TV too got a "bow" at the bottom of the screen. Seem like many suggested replacing this STK chip and also it's $10/each so I went ahead buy 2 to replace the 2 in my TV.
Below is a pic of the inside of my projector TV with the STK-392-110 circled in green and as you can see it is easy to ID due to the HUGE heat sink that it mount on to help dissipate the heat. (sorry for the small size since Fixya limit the file size to 150KB)
I unplugged the TV for more then 3 days and that seem to discharged most of the components.
So here are the steps I take to do the fixing.
1) Before I even order the chip I open it up to verify the part number and it was STK-392-110. Did many research try to find as much as I could about this chip and make sure I order the correct one... so I made the order. While waiting for the product, the TV had been unplug ever since.
2) Well, in order to even get to the inside I need to dismount the back panel. So it had stayed open ever since, of cause out of reach of children.
3) The components arrived and I prepared:
- soldering iron
- solder
- heat sink compound (used mainly to fill in a good gap for CPU heatsink inside computer)
- and solder sucker (the sucker later I found to be useless).
- Flashlights
- Screw driver
- Plier.
O, and my brother offer his help which I found to be very useful. My 2 hands weren't enough to do this work.
4) Removed the 4 screws which I marked with the yellow arrow inside the pic.
5) I didn't want to remove any cable afraid that it might create other problems but had to remove about 3 cables to make it easier to lift and move the board around a little while fixing.
6) Removed 4 screws that mount the chip to it's heat sink using a very short screwdriver. Very little space to work with.
7) It was extremely hard to remove the old chip with the board still cabled to the TV. Many times I was tempted to disconnect all the cables. What prevent me from doing so was I couldn't think of a good way to document all the cables that I disconnect and there are just too many (IMO). I did take many pics just in case.
Anyway, what I did might not be the best way but it worked. I tip the chip back and forth to weaken the pins to a point that it broke. It took forever but it did work. After the chip broke off that I can desolder and remove each pin with the plier. Again with the little space to work with that made me want to remove it from the TV. The pins holes were still very messy and full of solder. My brother came up with a way to clean the hole using stripped wires. When the stranded strip wires touch the liquid solder, it help suck the solder out of the hole. I'm sure there are better ways to clean the holes.
8) We had a little hard time putting the new chip in b/c a few pins bended a little and not align with the holes on board. And when added the compound to the chip, it made it even harder since now the chip need to stay away from the heat sink or else it'll stick to the heatsink. Finally we got the new chip in the holes on the PCB with the compound and all, so it just a matter of screwing the chip onto this heat sink.
9) Turn on TV and pic is 99% perfect again. Why not 100% U might ask.. b/c I saw a tiny out of align colors on the left of the screen. Not very noticeable but I can see it when I pay close attention.
Cost for the two chips were $20 included shipping. Hey, it's a lot cheaper then buy new TV and only 2 chips trashed instead of the entire TV. Anyway, I think I knew which chip went bad. Because one chip had hardly any of the compound. This compound help the transfer of heat to the heat sink.
Hope this help someone.
    Sergeant:
    Champion:
  • 375 Answers
Convergence amp ics are faulty.they start with stk numbers large in size,
Posted on Oct 28, 2007
SOURCE:
Words on bottom of screen are showing 3 times and are curved with green and purple colors
This tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.These parts must change to solved the tv convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 23, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What is phosporing screen
The colored spots may be a light engine issue that Panasonic will pay for repair costs even though tv is few years old. Contact Panasonic. . No you can't reset the lamp timer without a remote.
Oct 11, 2009 | Panasonic PT-52LCX65 44" HDTV
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
RED ARCH ON LEFT BOTTOM CORNER
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Jul 16, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Green arc across bottom of tv,and a little purple.
Replace Both of your convergence ICs STKs, big black ICs.
Jun 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT 47WX53 CinemaVision TV
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 21, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Green....purple....colors
If you are technically savvy and you can solder.....requires
chassis pull...replacement of convergence IC's...mounted on large heatsinks on board to the right looking in from rear....If
you want help........Let me know................T.
Dec 27, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
286 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
