Home | P.I. Engineering | X-keys Destkop Keyboard | X-keys and Window XP SP2...
P.I. Engineering X-keys Destkop Keyboard
Problem for P.I. Engineering X-keys Destkop Keyboard
X-keys and Window XP SP2 x64 (64-bit)
By fallenqangel on Sep 28, 2007
Since MacroWorks II claims to work with Windows x64, I figure there must be a way to program my X-keys on my OS. Only, I can't seem to find the drivers needed to successfully switch to the Programming Mode, nor does the tray icon let me start the MacroWorks II Program.
What drivers do I need and where do I find/get them?
This is what I did:
I installed MacroWorks II and ran it; the tray icon wont let me click on the "X-keys MacroWorks II" on its context menu - only on "Exit".
Switching to Programming Mode on the X-keys pad triggers the windows´ "New Hardware Found" wizard and I can't seem to find the drivers anywhere (was hoping that installing MacroWorks II would install them too, since that is all the help and guidance the official page offers).
Comments:
Sep 28, 2007
- Oh, yeah - btw, I have tried to install the X-keys 4004 Drivers (Xkeys4004.zip), following all the recommended procedures...
X-Keys board work just fine otherwise as long as a don't put it in Programming Mode, which results in both LEDs turning on, windows trying to find the drivers and locking the board. Switching Modes does not put the board back inte Normal Mode - only way to recover is to replug the USB cable, while in normal mode.
Same Problem
Mar 03, 2008
-   Same issue here with Vista (64)-   Guest
Dec 06, 2007
-   having the exact same problem with Windows XP SP2.
emailed www.xkeys.com support, but no reply.
-   Guest
Best Solution
posted on Mar 19, 2008
Helpful)
PIERocco
Rank: Apprentice
Rating: 92%, 2 votes
Hi guys,
Unfortunately programming in Memory Resident Mode on Vista will not be supported, however if you program your unit on an XP or 2000 machine first you will be able to “run” your unit on Vista.
Because we are unable to program in Memory Resident Mode in a Vista environment we are currently moving to new firmware called MWII which supports a mode called Boot Mode. Boot Mode is very similar to Memory Resident Mode in that when operating in Boot Mode all of your X-keys device's macros are stored in the X-keys device's internal memory. Our MacroWorks II software is required to write programming to an X-keys device operating in Boot Mode or to read programming from that device.
I apologize for the inconvenience this will cause. If you have any questions for me please email me at: Roccol@piengineering.com
Was this helpful?
Yes
No
Solution #2
posted on Mar 10, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Download the Macro Recorder application from PI engineering http://www.piengineering.com/download/Macro_Recorder.zip and run it, you will be able to install the driver and program the X-keys unit using the Macro Recorder application. Wayne
Popular Solutions for P.I. Engineering X-keys
Questions and Unsolved Problems for P.I. Engineering X-keys
Do you recommend P.I. Engineering X-keys Destkop Keyboard?
Answer
Answer
the zooming and scrolling action doesn't work
Answer
I just purchased a HP programmable keyboard Model SPOS and want to use Design Wizard to program some... (More)
Answer
I have a mouse that spins the cursor in circles every 5 minutes. The the screen blanks out and... (More)
Answer
When I push the space bar instead of taking me along one space it takes me to next line
Answer
Dear Pie, I have just converted (from macOS9) to mac OSX (10.5 = Leopard). I am having trouble... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For P.I. Engineering X-keys...:
Top Keyboard and Mice Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Keyboard and Mice Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
