Question about Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000i
Can't seem to get the camera shifted to auto focus. The top data panel shows "M.FOCUS" and will not change. tried the focus-mode switch with no luck. Tried changing the battery, pushing all of the function buttons, program reset buttons, but it still stays on manual focus. Anyone else have this problem?
Is there a micro focus switch on the lens
On my lens if switch to Micro Mode the Auto focus is disabled, Also it is a stupid question but you are using a AF lens and not a xi series or manual focus lens.
Posted on Dec 14, 2007
I cant get it to auto focus
The trigger button is what controls the autofocus. Make sure the camera is set for AF not MF. That will also make the cmaera not focus.
Apr 27, 2014 | Minolta Dynax 7000i 35mm Film Camera
My tilt/shift lens isn't working with my Minolta Maxxum 400si - the aperture which is controlled through the lens won't communicate with the body, is there a way around this?
Is this an auto focus lens? Most shift lenses are manual focus. Also, because they shift, they can generally only be used on manual not he auto settings. If the contacts are not on the back of the lens then it will on communicate with the body
Sep 15, 2013 | Minolta Maxxum 400si 35mm SLR Camera
Is it possible to manually control the focus on this camera? (Konica Minolta Maxxum 400si SLR 35mm Film Camera) I need to be able to manually control the focus, apeture, and shutter speed for a film...
The description of the manual focus is available in part 2 of the manual, page 40. The manual is available as a PDF here: . It is the seventh camera in the SI series in the list.
To manually focus the lens, press the focus-mode button on the front of the camera (bottom left when you are behind the camera) until M. focus appears in the data panel. If you have an AF lens, turn the focusing ring until the subject appears sharp. If you have an xi-Series or AF Power Zoom lens, pull and turn the lens control ring.
The focus indicator will light when the subject is in focus. To return to autofocus mode, press the focus-mode button again. The camera will also return to the autofocus mode if you press the program reset button.
I hope this helps.
(in manual focus, you can take a picture even if the subject in the focus frame is not in focus. Often it means you need to take multiple pictures to get a good shot of the subject. The advantage is that you can get some interesting shots.)
Feb 07, 2011 | Minolta Maxxum 400si 35mm SLR Camera
You push the button and it will not take a picture. I put new batteries in it and it still will not take a picture.
My HTsi Plus never seems to be able to Auto Focus on a subject, so when you push the shutter button half-way, it just flashes the focus indicator (telling you it is unable to focus). Try switching over to the "Manual Focus" mode. On the front of the camera there is a button labeled "AF/M". Push that button to switch to manual focus. If the camera is in manual focus, the external LCD screen will say "M.Focus". Now try to snap a shot. If that still does not work, there may be something wrong with the camera or the lens. So, try using a different lens in manual focus mode. If it still does not work, then I would say the problem is with the camera itself.
Nov 15, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Maxxum 7000 are cheap these days. Get a used one on Ebay and keep yours for parts.
Better yet, get a 7000i, 700xi, 650xi, 800xi or a Maxxum 5, 7, or 9. Why? More focus points, faster AF, more options, same lenses. But you will need to replace your flash.
BTW...remove batteries when you aren't put it away.
Oct 04, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Turn auto focus off?
On the left side of the lens right below the silver lens release button there should be a grey switch with the initials "AF" and "M". Switch it to "M" for manual.
Feb 16, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Sorry, the mounts of Minolta manual focus lenses are different than their auto focus series. Sigma, Tokina and Tamron all make compatible zoom lenses to fit the Maxxum series cameras
Dec 30, 2007 | Minolta Maxxum 400si 35mm SLR Camera
Monilta 7000i
send it to a camera shop,the fungus may have spread to the flex circuit under the top cover. there are no new parts for this model so finding a camera repair shop to clean it may take a few tries.
get an estimate first.
Dec 14, 2007 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000 35mm SLR Camera Logo
202 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
