Question about HP Pavilion a450n PC Desktop
Power Switch trouble
Hi there! I have a HP Pavillion a450n that is just about 3 years or a bit older. It works wonderfully and I've really had no problems with it. However, yesterday I went to turn the power on with the power button on the front of the tower and it would not turn on. Since I have it plugged into a power strip with the other peripherals, the small green light on the back of the tower was lit up. The power button does not appear to be "stuck", but I'm not sure. I have unplugged the tower and let it rest and reset overnight. I have also checked the connection of the cords on the back of the tower, but as I mentioned, it must be getting electricity, because the small green light on the back of the tower remains on. I have sprayed the vests with compressed air to rid any dust on the inside. Has this happened to any one else? Can it be fixed without taking to a Best Buy or Circuit City (my friends have had some horror stories about their files being lost or erased when using their services). I consider myself average or slightly above as far as computer literacy. I'd appreciate any feedback from anyone, especially the Experts! Heidi
  • 1 more comment
  • hlpc Sep 28, 2007
    Also, the sentence in my previous post was supposed to say :
    "I have sprayed the VENTS with compressed air to rid any dust on the inside."
    Thanks!!
    Heidi
  • hlpc Oct 01, 2007
    Thank you for the great advice!! I will be trying that in the next few days and will let you know how it worked.
    Heidi
  • hlpc Dec 15, 2007
    Thanks Techwildcat !!!
    Thank worked!!!
    You're the best :-)
  • 62 Answers
Hi, I have seen this problem before and it was related to circuit failure, let us hope this is not the case! From your posting I understand that your computer won't turn on now. So the next step is to reseat the components inside the tower. The first thing you need to check is the connection from the switch to the mainboard. Open up the case and follow the swith wires to the main board. They should be blue and white wrap around each other.If the connection looks fine then disconnect it and then reconnect it. Try the power the computer on. If it doesn't come on then we will need to do the next step. Open up the case and remove the RAM and place it back in, then diconnect the hard drive and reconnect it. Then disconnect the powersupply from all everything including the mainboard and then replace it. Then try to power it on. If you need help with any step of this posting feel free to start a live chat with me and i'll walk you through it. Let me know how it goes. Good Luck
Posted on Sep 29, 2007
A450N needs new monitor - what monitor specs are required?
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
Apr 23, 2012 | HP Pavilion a450n PC Desktop
Hi. I have a HP Pavillion dv7 Laptop. I've had it for approx. 2 & 1/2 years. For the first year I really didn't use it at all. I was working too many hours and working in a call centre, the...
The problem very likely may be dirt. Dust and dirt accumulate in the air passages and heat sinks in laptops often causing them to overheat. You say that the laptop was serviced by a technician recently.
He should have cleaned it's cooling system but he may not have. I have found that if the machine is not completely dismantled the dust and dirt blocking the free flow of air may not be visible.
Another possibility is that your cooling fans are waring out. These can be replaced. Also you can purchase high performance fans that are quieter, more efficient and last longed than the standard fans that laptops are supplied with.
Being as you have so much invested in this machine it makes sense to check to see if you have these issues.
Hope that helps.
Jul 06, 2011 | HP Pavilion dv7-1245dx Notebook
My hp pavillion computer shuts down same time nearly every day.
This is probably due to having a scheduled task that shuts down your computer. Check your scheduled tasks, and delete the restart entry.
Mar 23, 2011 | HP Pavilion a450n PC Desktop
I had an application called "creatacard gold 3" on my old computer with xp. I have all my important information from past 10 years is on that application. the computer crashed and i needed to buy a new...
The CreateACard Gold 3 (CAC Gold 3) will never work with Windows 7 64bit unassumingly because the software producing company has not upgraded their software for even Vista 64bit.
I recommend you to switch to " Hallmark Card Studio Special Edition" it has all the features of CAC Gold 3. You will enjoy it as there should be no problem installing it with Windows 7 64bit.
Good Luck!
Sep 21, 2010 | Computers & Internet
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Jun 05, 2010 | HP Pavilion dv4000 Notebook
No power from cord to computer
Hi...
If your laptop is under warranty go back to the manufacturer. If not go to hp center and buy a power cord of your charger which is totally fix to the charging hole.
Good luck
Regards
PCmania
Sep 25, 2009 | HP Pavilion dv9000z Notebook
HP Pavillion touchpad schroll not working
one of 3 things have happened
1 drivers got messed and need to be reinstalled
2 touchpad failed
3 touchpad was switch off by mistake
(some laptops have really tiny switches for the touchpad and wireless)
Jun 15, 2009 | BenQ Joybook 5100U Notebook
My hp a450n won't turn on. We had a thunder storm
Was the PC running when the storm struck? In that case changing the power supply knows as SMPS which is inside the cabinet needs to be replaced provided your monitor when independently connected to a power outlet, gives a display or says 'no video signal'...................sodeep
May 15, 2009 | HP Pavilion a450n PC Desktop
HP Pavillion 400 Power switch problem???
Could be your power supply is broken. That is a very common problem. Sometimes the computer will keep on restarting when the power supply is about to give way. I doubt it's the motherboard that is causing the problem, but then again i have never had a motherboard fail on me.
May 03, 2009 | HP Computers & Internet
HP Pavilion dv9000 Problem
I understand that your Notebook is not booting into windows.
To isolate the issue please try to boot the Notebook in Safemode.
Restart the Notebook and keep pressing F8 key and select Safe mode to boot.
Please try to perform the following steps also
= Power Drain =
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and Battery.
5. Turn on the Notebook power.
If your Notebook is booting into Safemode. Then try to restore the Notebook to factory settings. Before restoring the Notebook backup your data.
I hope this will work.
Thanks
Aug 12, 2008 | HP Pavilion dv9000z Notebook
HP Pavilion a450n PC Desktop Logo
180 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
