Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony trinitron messed up
My nephew pressed a bunch of butons on the tv and the remote. Ever since then the volume turns itself up to the loudest volume it can be. The remote no longer works except to turn the power on. None of the buttons work on the tv except the volume. We know that the volume button is not stuck on the tv or the remote because there is no batteries is the remote and it still turns itself up. Right after it happend it would keep going to tv video and then to setup and the menu, but now it does nothing. Also it is in another launguge that I don't know.
  • Anonymous Mar 17, 2014
    Everything works except sound. Volume up on remote and tv
    Genius:
  • 1,694 Answers
1)Try hard reset = unplug ac cord for a long time 12-24 hrs.
2)Volume up tactil switch on TV could be defective--replace.
3)Other menu selection issues cannot be addressed until vol up
trouble is relieved........T.
Posted on Oct 29, 2007
  • Vista Electronics Nov 06, 2007
    Just a quick thought ---- How does taking the batts out of remote
    unstick or repair vol up on the set ??
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Pressed a bunch of butons on the tv and the remote means first of all it is due to that buttons as they might be loose fron inside or broken contact. if remote & tv buttons ok check for sound section in tv. if you are not tech person get tech help it is a simple job.
Posted on Sep 29, 2007
Need to reset the tv/remote on a sony trinitron
Make sure you have fresh new batteries and installed correct,point the remote at the tv,make sure nothing is blocking the view of the IR sensor,get close to tv,but not to close,press power.If it still dont work, try the tv itself,press power,you may need to replace the remote,or the IR sensor, hope this helps.....
Mar 08, 2010 | Sony Televison & Video
I have a sony trinitron XBR 32 inch... The pip was turned on by accident, but i don't have the original remote. How do i turn off the PIP? Thanks in advance.
pls. use remot menu key and open main menu use DW key and select system menu see the PIP option is "ON" set option is"OFF" .
See the PIP screen is clear.
Oct 20, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Static noise and when put on max volume still not
sounds like blown speaker inside set. have you tried an external sound system?
Sep 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
No listing of 3 digit codes for Sony Trinitron, RCA universal rem
  1. Turn TV on.
  2. Press and hold TV button and Power button until light stays on.
  3. Release both buttons.
  4. Aim remote at TV and press the power button every 5 seconds until TV turns off.
  5. Press stop button at bottom of remote.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Mar 14, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Trinitron tv don't turn on
check power supply and H.O.T
also 0.01 ceramic fusabl resistor.
Jan 08, 2009 | Sony KV-20S42 TV
Sony FD Trinitron WEGA TV Model Number KD27FS170 volume problem
my sony trinitron is blinking six blinks and I cannot turn it on, please help
Nov 22, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony 20" TV controls problem
try to disconnect your power inlet cable 110v within 5mn to make a big reset and restart your tv and reconfigure all
Mar 31, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony 36' TV Volume Goes up on own/Stuck on Video 2
There's a setting in the menu. I think it's called "smart audio". It's supposed to adjust the volume automatically for commercials. But I don't think it works that well. Give that a try.
Jan 09, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Controls
Someone push the volume up button too hard and is stuck,this also has the micro(brain) confused,all this happen before you fund out your remote would not work.
Sep 03, 2006 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
190 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
