Question about Lexmark Wheelwriter 3 Typewriter
No start up
Just bought a used Wheelwriter 3 and when you turn it on, it goes through start up cycle (wheel turns and it beeps five times) and then light 1 and 2 on right side panel blink and nothing. I blew it out with air. Put in a new ribbon and a new set of batteries in the back and if you push any key it beeps five times and light 1 and 2 light up and blink. What do I do? What is wrong? Thanks in advance, Fred San Diego
  • Lexmark Master
  • 3,594 Answers
If your WW3 has batteries it must have spell check or printer options there is a small door on the top right of the machine.
open the door and unplug the plug you find there and try it.
Posted on Oct 24, 2007
Wheelwriter 6, flashing #3 beeps 3 times. press any keys twice and it will type.
You batteries need to be replaced, and or the battery holder is
corroded. Should be removed and cleaned so acid does not leak inside the machine.
Batteries hold the margins and tabs when turned off, not real necessarry.
Jan 22, 2016 | IBM Wheelwriter 6 Typewriter
How do i get my wheelwriter 30 back to original settings/
Take out one of the batteries from the battery holder and turn it on. The batteries are used for the memory of the machine. The machine will beep 3 times indicating the storage is cleared
Aug 28, 2014 | IBM Wheelwriter 30 Typewriter
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
What are these 2 blinking lights on my irobot roomba?
"The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
* Pulsing Amber - Charging
* Green - Fully Charged
* Amber - Partially Discharged
* Red - Almost Fully Discharged
* Flashing Red - Fully Discharged"
At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
GREEN = MISSION COMPLETE
YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
number of beeps after ?uh-oh? :
No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
9 beeps: Sensor error Please contact iRobot Customer Care.
10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
place it got stuck.
Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
If this does not correct the problem, please call customer support at 877-855-8593
Nov 22, 2012 | Vacuums
Wheelwriter gives 3 beeps when turned on. Meaning?
Try this. Remove the batteries, turn off for 30 sec. turn back on.
This will set everything to default settings. IT WILL ALSO CLEAR THE MEMORY!!!
DickyO
Mar 19, 2010 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 10 Series II beeps
either the carriage home position sensor flag is broken or the daisy wheel can't find home. try removing daisy wheel and re-installit. turn unit on and see if daisy wheel spins if it does then the carriage home position sensor has a problem.
Nov 13, 2009 | Lexmark Wheelwriter 10 Series II...
WW6 will not type.
Check to be sure the printwheel is properly installed and that there isn't any debris in the printwheel area. DickyO
Jun 02, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 Series II beeps
Three beeps and the space lights blinking means the batteries are bad replace them and be sure the holder is clean.
DickyO
Feb 14, 2009 | IBM Office Equipment & Supplies
Wheelwriter 15 series II
The ribbon drive motor might be n/g. I think 6 beeps is the ribbon motor located under the gear on the ribbon cartridge.
Feb 08, 2008 | Lexmark Wheelwriter 1500 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
