Question about Mitsubishi WS-65903 65" Rear Projection Television
Mitsubishi WS-65711 power-on problem
Pushing power-on button results in the Timer Light flashing but does not allow the screen to power up. I've turned the power source off-on trying to reset it, but same status. I tired the System Reset to see if that would clear it, but the Timer LED is still flashing like it thinks it should time-out. I waited a 120 (the max setting for the timer to see if that was preventing the screen from powering up .... but same results, the time lights keeps flashing. What should I try next ? Canoe Man
  • 1 more comment
  • canoe man Oct 03, 2007
    a local tech checked the TV and said the three color guns seem to have leaked onto the IC board. This is common problem with 4 year old Mist WS project TV's. Estimated repair of all three guns and failed IC's, testing of all IC's to be sure pending failures are checked and burn in test expected to be $ 700.00.
    I was told the color guns contain glycerin to cool the guns, which expands when heated into an over fill area with a seal. The seals dry and fail 3-4 years on avg. Then the glycerin drips down on the IC boards below.
    Does this sound correct based on your experience ?
    Canoe Man
    A local tech checked the TV and said the three color guns seem to have leaked onto the IC board, causing the timer light to flash as a warning indicator. The flashing LED can not be reset because it is detecting a failure in the electronics in the IC rack right below the color guns. They say this is a common problem with 4 year old Mist WS project TV.
  • Anonymous Jan 06, 2008
    green flashing light problem...tv won't power up...no picture...could lightening have caused this or is it a design problem with the big screen projection tv's?
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Posted on Apr 03, 2009
  • 1030 Answers
SOURCE: Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Posted on Jan 08, 2008
teeNjay
  • 5 Answers
SOURCE: WS-55909 Mitsubishi Big Screen TV timer keeps blinking
it must be recording soething have u got IQ?
Posted on Dec 30, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
Posted on Aug 29, 2009
  • 8457 Answers
SOURCE: I have a Mitsubishi Tv, WS-65711. The colors have
Ur convergence it dead.Must change the convergence ICS.Know how to solders?Buy a convergence kit,use what in that kit.Tries these websites.Tv repair World.com,Tv Repair kits.
Posted on Nov 10, 2009
Mitsubishi WS-65711
hold power button on 5 seconds to reset if this does not work vacuum any dust out of the back where the bulb is that's a warmning your getting ready to burn up the nulb, they are not cheap about 100.00 online and they do have mercury so touch them or drop them just try cleaning any dust from the fan in the back that should take care of it overheating as that's why your getting the flashing, or try the manual reset with the buttons on te front
Jan 28, 2014 | Mitsubishi WS-65711 65" Rear Projection...
Tip
Reset Mitsubishi WS-65711 VChip Password
Bypass or Reset Mitsubishi WS-65711 HDTV V-Chip Password Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi 65711 HDTV Parental V-Chip parental lock? Have you forgotten your V-Chip passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password.
When your passcode is requested, press the number 9 and the QV button on the original TV remote control at the same time. This process temporarily unlocks your TV.
When you enter the V-Chip Lock menu, pressing the number 9 and the QV button on the original TV remote control at the same time will delete your old password and prompt you to enter a new passcode. Pressing HOME at this time will cancel the entire passcode.
I hope that helps.
________________________________________
Mitsubishi WS-65711 Manual Download
Bypass Mitsubishi WS-65711 Front Lock
on May 04, 2010 | Televison & Video
Tip
Bypass Mitsubishi WS-65711 Front Button Lock
Would you like to bypass, defeat or reset your Mitsubishi HDTV WS-65711 Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi WS-65711 HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Mitsubishi-ws55859 power failure flashing timer green light
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi 52" WD52725 flashing green timer light
your projector bulb went out. you need to call the manufacturer and order a new bulb. they cost 300 to 400 dollars a piece I believe your tv only has one bulb and they are really easy to install.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Mar 06, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Tip
Download Mitsubishi WS-65711 HDTV Manual
Have you misplaced your Mitsubishi WS-65711 HDTV Owners Manual?
Would you like a digital, searchable, pdf version of the Mitsubishi WS-65711 HDTV Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
__________________________________________
Tip
I hope that helps.
on May 04, 2010 | Mitsubishi WS-65711 65" Rear Projection...
Mitsubishi 65711 Trouble
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 14, 2008 | Mitsubishi WS-65711 65" Rear Projection...
Tip
I hope that helps.
Tip
I hope that helps.
Televison & Video Logo
117 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
