Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Low Suction/No Soap
My Bissell 7901, does not dispense the soap and the suction is very low.
    President:
  • 1,673 Answers
Check the seal at the bottom of the dispenser, it needs to be on the valve not sitting in the hole, part 2101795 if you need to replace it. If suction is low, check the filter on the bottom of the tank lid, if clogged, suction will be low. Also check window gasket, sits between the tank and the nozzle window, if missing, you won't have any suction part #2104052.
Posted on Jan 17, 2008
How do you get the window gasket to fit into the slot
Posted on Feb 01, 2009
SOURCE:
Ther is no suction in the power tool hose . the soap is dispensed but no suction or at best a very very very faint suction
This sounds like a clogged Lint Filter. The filter (looks like a screen) is located on the Tank Cap. Remove it and clean and put it back. Don't run the unit without the filter. If that doesn't work then try the Flow Indicator Filter (Turn the Flow Indicator cap counter-clockwise to remove it, lift out the rotor and filter. Clean filter and reassemble in reverse order. You can contact Bissell Consumer Care at 1-800-237-7691 for a person to person contact if you need more assistance.
Sep 23, 2015 | Bissell Proheat Upright Carpet Cleaner...
Water wont come out
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying something else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 21, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
It won't dispense water or suction it up
I have a Proheat 2X and had the same problem. I don't know if this will work with your unit... but I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
Apr 19, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell proheat 7901-1 steamer won't **** up the water
Sounds like either the pump is not working or the collection unit has an air leak.
Apr 01, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Proheat wont spray soap with uniformity
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhkl
Sep 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Not dispensing water and no suction
I'm assuming the belts are OK.... Your heater is clogged. Unplug the machine and let it sit for 30 minutes. Take the handle apart, there will be a 4 inch by 8 inch metal box inside. This is the heater. Remember I said to let the machine sit for 30 minutes? If you didn't, the heater may be EXTREMELY hot!! Disconnect the two hoses going into it, and clean the metal pieces out (that the hoses connected to) with a needle or very small drill bit. You may want to remove the 6 or 8 screws holeding the heater together and remove the cover to clean it out. Reassemble and fill both tanks with VERY hot water ONLY and run the machine to rinse the entire system.
To prevent future reoccurences... use only Bissell extraction shampoos. Never put anything in the detergent tank except shampoo. (And only water in the water tank) Mixing chemicals with anything else turns the water/detergent mix to sludge. Also, when finished shampooing, put ONLY water in both tanks, and run the machine until one of the tanks run out of solution. Doing this rinses the hose lines out and prevents hardening of the solution in the heater ports.
I've fixed these machine for years. No dispensing is almost always the heater clogged.
Sep 29, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
229 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
