Question about KLH R3100 Receiver
Setting presets on KLH R3100
How are the presets programmed? thanks
  • Anonymous Dec 29, 2007
    klh r3100 is a weird one. doesnt program like others!!!!!!!!!!!! how do you set presets for tuner without remote?
No, not so easy, this isn't like your average car radio, unfortunately. This was driving me nuts, too, but I finally found a manual. Hopefully you have a remote, since that is needed.
Once you are on the station you want to save, press MEMORY on the remote. MEMORY will blink on the receiver's display. While MEMORY is flashing, press the button(s) on the remote for the number you want to save the station under.
Neil
Posted on Dec 26, 2007
No, that is how many presets work, but not on this receiver. This was driving me nuts, too, but I finally found a manual. Hopefully you have a working remote, since that is needed.
Once you are on the station you want to save, press MEMORY on the remote. "MEMORY" then blinks on the receiver's display. While MEMORY is blinking, press the number button(s) on the remote that you want to save the station under.
Easy! Just get to the frequency / channel you want, the press AND HOLD the preset key until the unit registers it (takes a few seconds.
Jaime
Posted on Dec 12, 2007
SOURCE:
What are the buttons for
Hello
There is no free download. If you want to get its manual, there are some paid download sites; and hereby send it to you. Just try them.
www.tradebit.com/...php/131951826-klh-r3000-r3100-quick-manua...
homeaudio.englishmanuals.com/stereo.../klh/r3100_2-188736.htmlCached
printfu.org/klh+receiver
Feb 12, 2012 | KLH R3100 Receiver
When i tunr my KLH R3100 it gives me an error massage that says PROTEC then powers down. i thought that it was because of poor ventalation but it has pleanty were it is set up. thanks
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 21, 2011 | KLH R3100 Receiver
Don't have a manual or the remote for KLH audio video receiver model r5100. Cannot figure out how to program the presets on the am/fm radio. Can someone tell me how or do I have to have a rermote to...
There should be numbered buttons on the receiver.Set the channel to what you want to preset,then press and hold down the numbered button you want.The sound will probably go away for a couple of seconds but when it comes back on the channel is preset.If you press the band button while you're already on FM and it goes to another FM,you can also preset more channels for FM.There should only be one AM band,then it will switch back to FM.
Good luck! Greg
Aug 10, 2010 | KLH R5100 Receiver
Klh reciever
You do not know what you have to replace. You test the component on board, starting from the amp, you need a multimeter and service manual schematic to do this.
After finding faulty component you will need to use solderer and thermal paste to replace it, and you need experience, or you end up damaging the board.
Ave you done anything like this before?
I am going offline now, if you have more queries I can answer tomorrow
thanks
Sep 11, 2008 | KLH R3100 Receiver
Klh home receiver problems
It is not a fuse problem, when a fuse is gone does not start at all.
It is probably the final amp circuit, there is a faulty IC in there that overheats after few seconds and the unit goes off by itself.
Klh r7000 no sound
go to this site dexsoft.com/blog. Is under : KLH R7000 no audio repair. Problem solve
Oct 14, 2007 | KLH R3100 Receiver
KLH R3100
Try pushing the speaker button under the power button on the front.
Aug 02, 2007 | KLH R3100 Receiver
KLH Scratchy Channel
Return the unit to where you purchased it and get a new one.
Sep 19, 2006 | KLH R3100 Receiver
KLH R3100 Receiver Logo
1,373 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Gil Shultz
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
