Question about Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor will not turn on
Whenever I try to turn my monitor on, the light never comes on and it just stays off.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
1 check plug & socket 2 check for cord 3 power supply in monitor to br checked 4 if it is ok check for horizontal section. if you are not tech person get the help. good luck
Posted on Sep 29, 2007
Monitor powering on when ignition turned on
chack this:
is the revers light is turn on whan you shift to revers gear???
dos it turn off???
if its not on chack for burn light balb . than you will see that the revers light unit id stuck on "on" mode.
Dec 16, 2013 | PLCM8200 8.1" Rearview Mirror Monitor w/...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
There is just no way you will be happy to hear it needs service or replacement under warranty.
Worldvet
Jul 03, 2008 | Relisys RLT1720 17" LCD Monitor
Monitor not coming up
try unplugging the monitor cable from the computer and check if you get a power on self test displayed
if yes then the monitor is fine we have to troubleshoot the computer
and if nothing is displayed the monitor needs to be replaced.
Jun 05, 2008 | Dell OptiPlex GX260 PC Desktop
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
I am not familiar with your particular model, but I do know what the problem is.
The inverter that runs the lights behind the screen is faulty and needs to be repaired. The lights shine from the top and bottom and reflect outwards through the panel so you can see what is on the screen. If you start the computer up, then shine a bright light into the panel you will see an image on the screen, but very feintly.
This can be cheap, it can also be expensive depending on where you go to get it repaired. Call aorund to a few TV shops in your area to get a rough idea on prices.
Hope that helps =)
Apr 11, 2008 | Sceptre X7GNAGAV 17" LCD Monitor
The green power light indicates that the monitor is receiving from the computer correctly. I suspect it is going into high voltage shutdown. There is a safety circuit that monitors the high voltage and shuts the monitor down if it sees anything amiss. So the monitor comes on and then shuts off. High voltage problems are generally not worth trying to repair. Another example of a worthless safety feature. High voltage failures are not dangerous, and adding the safety circuit just kills the unit when it may have some life left or worse, sometimes it is the shutdown circuit itself which fails!
Hope this helps.
Jan 10, 2008 | BenQ FP731 17" LCD Monitor
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Fp 7317
My monitors green light stays on, but the screen will come on for a second then goes off
comaq fp737
any ideals
May 15, 2007 | Compaq FP 7317 17" LCD Monitor
Kogi l7eh-ta ko 17" Flat Panel LCD Monitor Logo
64 people viewed this question
Top Kogi Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
