SOURCE: Vermont Casting Radiance Gas Stove (RUVSOD) NG to Propane (LP)
Unfortunaletly, due to the delicate nature of vent-free appliances, you'll find that most are not field convertable. If the vent free appliance were to lose its efficiency, you would be subjected to high levels of CO, carbon monoxide, and could likely die. Therefore, field conversion is not recommended and in this case, not possible. Vermont Castings does not provide parts to convert and if they did you would be essentially replacing the entire unit short of the outer cast shell. I wish you luck.
SOURCE: ventless fireplace
Hi; The BTUs will be on the lighting instruction plate stored where the gas valve is. If no data plate google the manufacture for the information...alpharome416
SOURCE: Conversion
Hi get a gas fitter to do this he will tell you if this can be done not a d i y job
SOURCE: I have a Dyna-Glo model
You cold do it but it would be costly. You would need to buy a new LP gas valve assembly, a new LP regulator, and a LP safety ODS pilot. These come from the factory specially for LP or Natural and cannot be converted using the crank down and flip method like you do for stoves.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: I have a
Harbor freight sells the blower motor on internet
charmglow has been bought and sold by Home Depot. It has been
a total pain in the *** trying to track down this blower motor.
the new Company is procom, www.usaprocom.com
go to harbor freight and type in procom and the blower motor will pop up.
[email protected]
