Question about Technics SL-1200MK2 Turntable
Loose tow arms
Losse tow arms how do i tighten them up
  • 515 Answers
If you continue to have issues with your tonearm, you will need to have the tonearm replaced. Those screws are machine calibrated, so they are very hard to get back to the original factory positions.
You can buy the tonearms HERE, and even have them replaced by them as well - they offer free return shipping on all repairs outside the NY Metro area. Within the NY Metro area, you can drop off, or schedule a pick up.
Posted on Nov 02, 2007
    Problem Solver:
  • 7 Answers
Do you mean you have a loose arm? If so tighten the bolt right above the arm of the turntable lightly turn in to the right ,, not to much cause you can bust your balls.
Posted on Oct 19, 2007
York C202 crank arm tighten
Here is an article on changing and tightening normal bike crankarms. It should apply to your bike too. If you see a plastic cover, try to take it off and see what you're dealing withm How to Tighten the Crank on Bike
Feb 09, 2017 | Cycling
Tip
One windshield wiper is working, but the other isn't
When one windshield wiper isn't working like it should it may be a loose nut. The nut is located at the base of the wiper arm. There may a plastic tab covering the top of the wiper joint. You should see the nut when the tab's removed. <br /> Check the nut for tightness. If it's loose the wiper pattern will probably need readjusting. Reset the arm by loosening the nut to where you'll be able to move the arm. Set the arm where you believe the it should be. Tighten the nut and run the wipers. If the wipers are working well with each other, and you're satisfied with the windshield coverage finish tightening the nut. Replace the plastic tab.<br /> If the nut comes loose repeatedly you may want to apply a small amount of threadlock to the threads before readjusting the wioer and tightening. Use only a small amount of threadlock.
on Feb 26, 2011 | Buick LeSabre Cars & Trucks
The upper spray arm came detached, how do I reattach it?
On my dishwasher, this arm attaches with a huge gray plastic screw. If it comes loose, you'll usually find the spray arm sitting in the bottom rack, but the screw falls down to the bottom of the tub.
The spray arm has a hole that goes all the way through its center. One of these holes is larger than the other, so the arm will only attach in one direction. Most of the spray holes on the arm face "up" when installed.
Slide out the upper rack, position the spray arm on its pivot, then insert the screw and turn clockwise to tighten it. The arm should spin freely.
If this arm isn't attached, none of the dishes will wash well (due to a loss of water pressure).
May 21, 2015 | Bosch SHU9915UC Dishwasher
How to remove arm wiper arm
sound like it needs tightening. flip up wiper arm end cover (at base of wiper arm) tighten nut. If its not loose the splines may have shredded. If this is the case a new arm might be needed but you can also use a twin pack chemical metal or devcom typ putty to make the difference. mix some up place it in the wiper arm, fit the wiper arm and remove excess putty, semi tighten arm and allow to go off. Then tighten arm when its fully cured
Jul 15, 2014 | 94-97 Chevy S-10 Pickup Pick Up Truck...
ROCKER ARMS SHACK I TIGHTEN THEM AN NOW IT WONT START WHAT SHALL I DO NEXT
The tolerance for rocker arms is very critical and must be exact. If you aren't knowledgeable in this field and have already tightened them I suggest you have your vehicle towed to a vehicle mechanic shop and have a professional straighten out what you have done in order to minimize the damage.
Jan 04, 2011 | Dodge Caravan Cars & Trucks
Alternator belt is broken
Get a new belt from an autoparts store, to suit your vehicle year and model.
The alternator has to be loosened to fit the new belt. There's usually two locations to loosen
  1. the top adjuster clamp arm; and
  2. the lower pivot bolt. On the 4cyl motors its in behind the oil filter. Uncertain about the v6.
Once loose, the alternator can be swiveled so that the belt will fit over the main pulley.
Make sure that the alternator does actually rotate. If not, get it serviced or replaced.
Swivel the alternator back down and tighten the clamp arm so there's about 8-10mm of movement when you press the belt.
Tighten up the lower pivot bolt.
If you don't have the tools or skills to do this, have the car towed to a garage.
Jan 03, 2011 | Eagle Talon Cars & Trucks
Rocker arm come out on jeep chrysler 3.7 eng
A rocker arm is the arm that sits on top of the valve stem and connects to the push rods 'the push rods sit on the cam so when engine is running, the push rods go up and down in a timed sequence and with the rocker arms, open and close the inlet and exhaust valves. the rocker arm is located inside the valve(rocker)cover .If the rocker arm gets loose or comes out.
Check the nuts on the shaft which holds the rocker arms.either the shaft or nuts are got loose.They need to be tightened.Don't make it too tight or too loose.  Too tight,and they don't flutter right. Too loose,and they allow the rocker arms to wiggle out of whack. Other possibility can be  something is broken, bent, collapsed, or out of adjustment.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2002 Jeep Liberty
Rear window wiper arm moves away from window, leaving it unable to wipe?
its possible the nut that tightens the wiper arm has come loose. just center the wiper arm in proper position and try to tighten the nut.
Dec 17, 2009 | 2007 Jeep Liberty Sport
Technics SL-1200MK2 Turntable Logo
256 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
