SOURCE: Canon CanoScan LiDE 60 not recognized by iMac or Mac Powerbook Laptop
Is the scanner detected in Apple System profiler? If so, what applications have you tried to access the scanner from?
SOURCE: LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
SOURCE: CanoScan Scanner can not complete a scan
Double-check all connections and try another port if possible. There may also be damage to cables or pins. Do you have another cable to try? Do other devices work in the same port?
SOURCE: Installing CanoScan Lide 20 / Lide 30 into Mac OS X 10.5.5
I found this scanner at a garage sale today, and had trouble finding this info myself. Finally stumbled upon this site ( http://cadwell.livejournal.com/39545.html )
I'm using it on a Powermac G5 but both the driver and toolbox app say they are univeral binary. Hopefully this gets you up and running too:
CanoScan LiDE 30 on Mac OS X 10.5
This technical help may seem completely
out of place on this art blog but after scouring the internet for 3
hours trying to set my 6 year old scanner up on my new MacBook, I found
this info half way down a lengthy comments section of a random blog. So I thought I'd post it here (slightly altered) as a message in a bottle to anyone else in need of it.
How to set up CanoScan LiDE 30 on Mac OSX 10.5
STEP 1:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=6623
STEP 2:
Select MAC OS X
STEP 3:
Download BOTH:
LiDE 20/LiDE 30 Scanner Driver Ver. 7.0.1.1aX
(Mac OS X)
lide20lide30n670un676un1240uosx7011aen.dmg
CanoScan Toolbox Ver. 4.1.3.0X
(Mac OS X)
CSTb4130MXE.dmg.gz
STEP 4:
INSTALL CanoScan Toolbox Ver. 4.1.3.0X
STEP 5:
INSTALL
LiDE 30 Scanner Driver Ver. 7.0.1.1aX . Make sure
Applications>CanoScan Toolbox 4.1>Plug-Ins is selected as the
install location.
STEP 6:
You will be asked to RESTART. You should.
STEP 7:
When
you run CanoScan you can choose Photoshop as the default program to
open the image in once it has scanned. You do not need Photoshop to
open using Rosetta for this to work.
NOTE: If you want to scan
directly from within Photoshop CS3, you need to copy the driver
'ScanGear CS 7.0X' which is found in Applications>CanoScan Toolbox
4.1>Plug-Ins into the photoshop pluggins folder, Applications>
Adobe Photoshop CS3>Plug-Ins>Import/Export. You also need to open
photoshop in Rosetta mode. Apple + I on the photoshop icon and select
'Open using Rosetta'. I would not recommend using this method though.
STEP 8:
Go to System Preferences>Accounts>Login Items and remove both of the following:
N067U_ButtonManager.app
N124U_ButtonManager.app
STEP 9:
SCAN.
