Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Once you're in the P mode, turning the command dial will change the shutter speed and aperture in opposite directions to maintain the same exposure (within the limits of the camera and the lens). You should see the shutter speed in the viewfinder change.
If you want absolute control of the shutter speed, change to the S mode. The command dial will then allow you to control the shutter speed, and the camera will automatically change the aperture to compensate (again, within the limits of the lens).
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
You can't manually change the shutter speed. It does change on its own when you change modes. If you want more control over shutter speed and aperture, you need to step up to a DSLR camera.
When you set the camera to "Full Manual" mode, you should be able to dial in your shutter speeds, for most film cameras, including the N55 30 Seconds is the slowest shutter speed. If your camera features a "Bulb" mode, then the shutter stays open as long as you are holding down the shutter release button.
The shutter is a copal shutter and it does change . Try 125th speed haer the sound and then change to 1/15th . Also you can tell on your histragram inthe camera or the image on your display .
If your shutter speeds are off you can compensate by changing the film speed setting, quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
