Question about Sony PlayStation 2 (PS2) Console
PS2 controller wires were pulled out of controller. looking for wiring schematics to repair at home. im professional electronics tech but no good without schyematics
1. red 2. black 3. green 4. brown 5. orange 6. yellow 7. blue 8. grey 9. purple
Posted on Sep 30, 2007
What does it mean when my Frigidaire professional series dishwasher has an error code of 91 and the China/Crystal setting light is illuminated?
Rod, Try unplugging or turning off breaker for ten minutes to reset. If this does not fix, you may want a good Tech. have a look, diagnose and estimate repair.
Code E91 could be User Interface to Main Control Board communication error. Communication problem. Check the wiring between the Main Control Board and the User Interface Board. Wiring bad, correct wiring problem. Wiring good, replace the User Interface Board. If the problem is not corrected, replace the Main Control Board.
What Is Error Code 91 On Frigidaire Dishwasher Professional Series
http://www.manualsonline.com/support/frigidaire/dishwasher/error-code-91-5195801
http://forum.appliancepartspros.com/washer-repair/476079-error-code-91-a.html
http://www.elektro-ivicic.cz/data/user-content/soubory%20ke%20stazeni/Electrolux-chyby.pdf
Jul 14, 2016 | Frigidaire Dishwashers
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
I need a schematic for a 2006 Jeep wrangler A.C. unit
sure you, can a schmetic of what.
freon loop
mech, parts
elect. schematics??? electronics controls. , air controls
this is called a FSM. ever heard of that>?
here it is , read the HVAC pages then the wiring chapter same topic
why not post symptoms and let me tell you how to diagnose AC.
HVAC
click TJ here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
bingo. the whole 100 pages. on one topic, or more.
if you dont know HVAC, why not just post the symptoms..
the FSM is for savvy mechs. with HVAC training.
im good on the electric side, and can also tell you if the loop is failing.
but im not a Freon LOOP guy, i do electronic controls of all kinds.
retired, now.
Aug 24, 2014 | 2006 Jeep Wrangler
I have just installed a new electronic control in my JTP45 Electric double oven. (part WB27K5273). I have a schematic, but so far have not figured out why that when I open the door the unit turns off and...
It does sound like a wiring mistake. Check all the connections and the wire colors against the colors on the Tech Sheet wiring diagram (which is normally taped on inside the control panel). Particularly look closely at how the door switch and lock connector is plugged in. You may have reversed the plug.
Best Regards,
Bruce
www.fixyourboard.com
Jun 18, 2010 | GE JTP45 Electric Double Oven
My dog chewed up my cord for ps2 guitar for guitr hero. can i use the wires & plug from a regular ps2 controller to fix it ?
to check this you would have to dismantle the guitar to the point where you can see how many wires are connecting im assuming no since im sure there are more for the buttons ect. But if you can find a electrical shop maybe even home depot and an electrician that knows what they are talking about they could help you find the right gauges of wire needed to resplice it and fix it. You could also just cut out the bad area and resplice it yourself. Just understand you want to make sure you do this right so if your not sure how to splice learn first and practice with other wires of same gauge so you dont end up doing it so much taht you run out of cord ....
good luck
Apr 18, 2010 | Video Game Consoles & Games
Creative Inspire 5300 Volume Control broken!
For those searching the answer "How to replace/repair Creative Inspire 5300 volume control":
Its simple : looking at the back of the suboofer, the pins are as follows from top right, clockwise : LED VDD , Balance pot middle leg, GND, pots + legs, Volume pot middle leg, on switch input. Connect one pots ends to GND and the other ends to pots +, connect a switch on GND and on switch input, anode of led to LED VDD, cathode to GND (there is a 1,8k resistor inside so no external resistor needed)
Dec 19, 2008 | Bose Companion III Computer Speakers
Front panel audio connection to the asus motherboard
hokuwho,
you seem to have found what i seek. im looking for a schematic for my dell latitude d600 to determine which pins of the 9 or so pin battery connection on the mother board require which voltages and or resistances to both supply the 11.1v battery voltage to run the computer, and the other signals voltages resistances etc from the two circuit borads inside the battery case that tell the computer to use the perfectly good fully charged li battery cells or not depending on number of charge cycles. my batttery stopped putting the 11.1 v, it still has alive and well inside, out to the computer mobo, and has stopped charging, or so the computer says, eventhough its fully charged, and yet will not run the computer. i ordered another battery and know why dell in thier infinite though misguided wisdom decided to prematurely kill the good batteries to avoid possible overheating and exploding. but i want for my own knowledge to determine how they are killing the output and possibly design my own circuit that does what they actually needed and meant to do, rather than have the number of charge cycles rule. id just detect battery temperature and ability to charge, and eliminate any counting of charge cycles which is useless, and results in killing perfectly good batteries for no reason. do you know what numberds i actually need to find a schematic. each time i attempt to search with the computer model number, i find schematics of other mfgrs completely different equipment with d600 in the model number, or rar files i cant open, and usually with added notes that downloading this file can harm my computer.
i have always built my own desk tops and fear no electronic circuit but software and file suffixes and wanings of damage to my computer and various types of files apparantly engineered only to confound and confuse give me a little trouble. i started in electronics at a time when each simple circuit stage was built around a single huge glass tube the size of a body builders forearm. and now im working on entire computers with less surface area than one of those tubes. but back when those tubes ruled, manufacturers were trying to build the best longest lasting curcuits they could and drew schematics that actually were intended to be capable of being read by any good tech, and were easy to find with model number, of the equipment. given a schematic i can repair most anything but i cannot find the schematic. but current circuits are desigend to purposely fail for no reason that makes sense so the manufacturer can sell more to replace them, and schematic are well disguised not only in the way thier drawn and marked but even where they are located. ive learned to read nearly all schematics and interpret any schematic symbol, but locating schematics online and getting them to my computer, is difficult for me, eventhough i have desigened and built my own electronic circuits my self all my life.
Nov 15, 2008 | Computers & Internet
Mutlitap stand doesn't work
check And see if it is a problem with the make of your ps2 slim. thats all i have for you. my ps2 slim is brand new. i just bought it last year & it works perfectly. multitap is something i dont know about. i went to walmart the other day & a guy who was an expert with videogames told me all i need to know. Just look forward to that
Oct 04, 2007 | Sony PlayStation 2 (PS2) Console
Playing burnt disks in my ps2
You need a mod chip. Search google for ps2 mod chips. This is a VERY VERY difficult process, in fact you'de be hard pressed to even find a tech willing to take on the job of soldering all the wires. When all is said and done the inside of your PS2 will look like a spiders web of wires. My best suggestion to you is to buy an already modded one. You are warned, unless you are an expert with a soldering iron and understand electronics very well don't attempt this.
Aug 17, 2007 | Sony PlayStation 2 (PS2) Console
Lost all control......dead
Thats an idication that theres a problem in the power supply or the sweep supply. I have seen the picture tubes to leak in this model and cause the boards to short out. These are the type of sets that unless you know what your looking for, Im sorry to say your not going to find it. Your goingg to need a schematic diagram, If you do not know solid state repair or dont know how to read a schematic Im afraid your going to need the assistance of a trained tech for this repair. There is no quick fix Im afraid. good Luck Ps dont forget to rate this please.
Oct 14, 2006 | Sony KP43T75GRAY 43" Rear Projection...
Sony PlayStation 2 (PS2) Console Logo
143 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
