Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
55 apex HD tv
I have a apex 55 inch and when when the tv comes on it's like a gost affect you can see the red and the blue it like a person is standing and the shadow is a little to the lef and right can you please help me be for i spend about $500.00 to fix it thanks so much spoony
The APEX and most rear projections are notorious for poor solder joints. The convergence circuits on your TV get very hot and the solder joints weaken over time. In your case, the convergence STKs are the large chips mounted to heat sinks right up front on the left hand side circuit board. Remove the board and resolder the STKs using a good low wattage iron. If this doesn't fix your problem try replacing the STKs. They aren't that expensive. They have 15 or so legs so you'll need some skills removing them. Good Luck!
Posted on Sep 30, 2007
SOURCE:
Have blue creen coming and go take copo 10 minute to coming back what make that proble
Hello
Will you please describe some more about the faul of your Apex TV? I can't really understand the problem of your TV by your description. Give me some more details by FixYa comment box. OK.
Jun 22, 2011 | Apex Digital AVL3076 30 in. HD-Ready LCD...
Blurred picture red and blue shadows
Please run the convergence feature on your TV. Its giving you double image because the red, green, and blue guns are dis aligned. By running convergence it will realign the guns properly. You need to run the convergence feature at least once a week. Please note this is only for CRT rear projection TV's and I assumed it was. If it is an LCD rear projection, then there's nothing you can do to fix such thing, but call a repair person. But if doing the convergence doesn't fix the problem, you need to call a repair person. But I hope you won't have to refer to the manual on how to go about it
Nov 29, 2010 | Apex Digital GB55HD09W 55" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
32" Zenith Television
This is due to electromagnetic field affected in the corner area. Check whether there is any magnetic components in surrounding area if found keep away from TV. And then switch off the TV and remove the mains plug also. Switch on the TV after 30mins. The colour will disappear. Even you got the same problem call technical person. Because the decaussing section is not worked.
Sep 05, 2007 | Apex Digital AT2008S 20" TV
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
211 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Ekse
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
