SOURCE: drive or overdrive dont engage
sounds like you need the gearbox looked at.... the adjuster pulleys in the in the gearbox are loose.. hope this helps
SOURCE: Rebuilt the Trans.(4L60E) in my
did you do the rebuild or did a shop do it? it sounds like the clutches werernt done properly. if the reverse is out the other gears will go out too if driven too far in that condition,
SOURCE: reverse is gone on 1995 chevy blazer s10-goes forward just fine
reverse clutch went out rebuild transmission
SOURCE: all forward gears work and shift fine....all the
There is a pin in the transmission that has sheared off or a band has come loose. Bottom line you need to have the transmission serviced and repaired.
