Question about Car Audio & Video
1999 ford explorer car stereo install
Finding out the wiring layout for a 1999 ford explorer stereo power wire.
  • Anonymous Mar 19, 2014
    trying to install a jvc stereo but the wires r different from the car and the stereo...
  • 626 Answers
Heres the whole list. 1999 Ford Explorer Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink (from the12volt.com) Best of Luck.
Posted on Sep 29, 2007
  • 883 Answers
It is a black with pink tracer wire coming from fuse #20 (7.5 amp) at the fuse panel through a connector behind instrument cluster.
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
Radio wire diagram for 1999 ford explorer
I have attached a link to many radio wire diagrams and also in it you will find the 1999 Ford Explorer's Diagram. I also attached the screenshot. 1999 Ford Explorer Car Radio Stereo Wiring Diagram
Apr 17, 2014 | Cars & Trucks
Were can i find a color coded wiring diagram for a radio in a 1999 ford explorer
For 1999 Ford Explorer Car Stereo Radio Wiring Diagram check this...
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: Blue
Car Radio Amp Trigger Wire: N/A
Front Speakers Size: 5 x 7
Front Speakers Location: Doors
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5 x 7
Rear Speakers Location: Rear Door
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Hope helps (remember to rating this free answer).
Oct 03, 2011 | 1999 Ford Explorer
Trying to install factory cd-cassette combo from a 1999 ford explorer into a 1996 ford crown victoria with only a cassette radio player. need to know wiring data on both vehicles.
Hi and welcome to FixYa,
On your need for the radio wiring of 99 Ford Explorer and a 96 Ford Crown Victoria, see below wiring scheme:
Confirm with a voltmeter on the +12 and an ohmmeter for speaker continuity.
Good luck and thank you for asking FixYa.
Oct 30, 2009 | Car Audio & Video
Having trouble finding the two 12Volt wires for the car stereo and can't find the diagram with the color codes for a 99 Ford Explorer XLT. Can you help.
almost all vehicles have a red and yellow wires that usaully both hot wires the yellow is usaully the egnition hot wire where as the red is direct to battery for the clock the black is the ground wire and the rest of the wires are for speakers they should come in sets of two of the same color but one would have a small stripe on it it`s the possitive side for each set of wires to each speaker. Hope this helped you.
Oct 29, 2009 | 1999 Ford Explorer
Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
Oct 02, 2009 | 1996 Ford Explorer
Can't find the amp in my ford explorer
The amp should be located cargo area on the drivers side. You will need to remove the panel to get to it.
Jun 23, 2009 | 1999 Ford Explorer
Need to hook up bass system to 1999 ford explorer can anyone assist me
Probably need an installer - depends on yr/make/model of car - stereo and wiring diagram for sub system. There are lots of questions need answering and if not installed properly, you can certainly damage the stereo, sub system. Subs use a lot of power and improper wiring could cause problems, even fires !
Apr 19, 2009 | Car Audio & Video
Wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Sep 29, 2008 | 1996 Ford Explorer
Car Audio & Video Logo
793 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
