Question about Lexmark Wheelwriter 3 Typewriter
Need a user manual
I just bought a used Wheelwriter 3 to replace my screwed up Personal Wheelwriter which arbitrarilly returns and locks up and won't tab over. On problem. The newer Wheelwriter 3 does not have a manual and there must be something tricky to get it to work. All I get is power on, and any key I push, it beeps and flashes on the right side panel in the line space area. Does anyone have a manual? Thanks, Fred San Diego.
  • 1 more comment
  • Jude01 Mar 28, 2008
    IBM Wheelwriter 3
    On all of the print wheels the bottom of the letters is not printing on
    the paper.
  • Anonymous Jul 23, 2008
    The line space indicator lights up and beeps with every key pressed. All attempts to correct the problem have failed. I can't find anyway to clear the error.
  • abcosnc Feb 25, 2013
    Ribbon lift needs adjustment
Oil rails not with WD. Machine oil.
I have instruction books $ 10.00 828-687-3929
Posted on Feb 25, 2013
Make sure it has new batteries - my lights flash when it needs batteries.
Posted on Oct 28, 2011
  • Lexmark Master
  • 3,594 Answers
How may beeps and what flashes?
Posted on Oct 24, 2007
Ibm wheelwriter typewriter will not return all of the way
Take a rag with some light oil like 3 in 1 oil or WD 40 and clean off the metal rod that the carrier moves across. Then apply some more around the entire rod with your fingers. The carrier should move much better after that.
Jun 13, 2012 | IBM Personal Wheelwriter By Lexmark
Need User manual for IBM Wheelwriter 2000
Go to and click tour way to publications you will find a users manual you can print out.
Jul 30, 2009 | Lexmark Wheelwriter 2000 Typewriter
IBM Wheelwriter 30 Series II issue...
This is automatic return, it can be turned off with code "R".
You can download a manual at click on publications.
Jul 03, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Personal Wheelwriter 2
I an very knowlegeable about wheelwriters, I will be in the office today until 5:00 pm edt you can call at 216-241-0027.
Mar 11, 2009 | Lexmark Wheelwriter 3 Typewriter
IBM Personal Wheelwriter 2
Look at the ribbon and see if the letters are on the very top of th ribbon. If so on the front of the carrier there is an eccentric screw for adj. ribbon height. Loosen the lock nut W/ a small 9/32 wrench and adj screw to raise ribbon. Be sure to check L/O with the underscore as you can get it to high.
Jul 02, 2008 | IBM Wheelwriter 30 Typewriter
IBM personal wheelwriter 2 memory
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is locked up
Mar 25, 2008 | IBM Wheelwriter 30 Typewriter
3500-4500 series lexmark
Can you make sure the number corresponds with the typewriter itself? Sometimes, the manual could be a typo/misprint.
Jan 20, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
120 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
