Question about Western Digital Caviar 40 GB Hard Drive
Partition error I hav an western digital 40 GB hard disk. there is no problem for detection in BIOS. But when i partitioned using disk manager (DM 9.4) it shows an error message"ERROR READING PARTITION TABLE" I also tried for partitioning FDISK, PQMAGIC But there is no use which software i need to resolve the problem
  • Jeruz Jan 04, 2008
    at first i had many data's and has 2 partation on my hardisk.. when my another hardisk i used to crate a OS and crate a Partation I accedntally opened my main hardisk which is the one i use to.. so wat I mad is create new partion.. and hoping to recover the data's inside of it.. but it turn to format it and 0/0 capacity..
    how can i recover my old partation and restore all data's in my main hardisk, when i created new paration same as the old?
  • fedz_rakizta Jul 29, 2008
    when I install OS it can copy until 100% but when I run it there will be a error...error loading OS...I format it Zero fill drive but still i cant install an OS...
  • 75 Answers
Try using the command FDISK /mbr. This should fix the master boot record. If not, then if you don't care about the data on your drive, you could wipe it clean with any of the several utilities available on the web and then try partitioning it. Search for "Wipe Disk" in Google.
Posted on Sep 28, 2007
SOURCE:
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
Drive only reports 56gb to partition - missing 100gb! How do I access the remaining space?
Click Start
Right-mouse click "My Computer".
Click "Manage".
Expand the "Storage" part of the tree.
Click "Disk Management".
View the diagram for your disk-drive.
Does it show the 56GB partition, followed by 100GB of "unallocated" space,
or does it show one (approximately) 160GB partition?
If the former, backup all the files in the partition (copy to an external disk-drive, or copied to DVD-recordable disks, or to another computer).
Then, use "Disk Management" to delete that "small" partition, and to define a new partition that "spans" the entire volume, and to initialize the partition.
Then, copy the "saved" files back onto the drive.
Dec 18, 2010 | Western Digital Scorpio WD1600BEVS 160 GB...
Wd drive PATA wdc-wd2000 jb - 00fua0 should be a 200 gb drive. said was running out of space and when checked found drive was only reporting it's size as 31.49gb. have tried everything I can think of to...
Check the hard drive for partitions, it could have several partitions, but only the first partition has been formatted.
Go to Control Panel - Administrative Tools - Computer Management - click on Disk Management and look at the Western Digital it could be Disk 1.
If you see unallocated partition, you can create and format this partition.
OR
You can delete the existing partition and create a single large partition and then format this partition.
NOTE - this process will delete the existing data on the hard drive.
Dec 16, 2010 | Western Digital (WD2000BB) 200 GB Hard...
I have an old st340014a hard drive which i would be using as a slave drive. all is ok when i first installed it on my computer. i noticed that it had 2 partitions as i saw it on "MY COMPUTER". i tried to...
right click on my computer and go to manage.then click on disk management.
Then on right pane you will see your hard disk partition table..If you see something in black color or green color right click on that partition and select create new partition and create partition. once you create partition it will be in blue color,then you can go to my computer and see the partition you created there.
May 26, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
What to do if the disk is not detected?
Hi ctieprabanda,
Check your bios, to see if it detects it there? If not switch the sata cables and try. If that doesn't work , then you have a dead drive.
Good Luck,
Mark
Nov 09, 2009 | Western Digital Caviar SE WD1600JS...
Hard disk failure..
YUP! this can be fixed. if u r runnig on XP the best software for this would be Partition Magic or if u r on Vista then Paragon Partition manager
i hope i helped!
Oct 22, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Samsung 40 GB Spin Point Hard Drive problem
try to use some Hard drive recovery programes or try Paragon partition manager.
Sep 29, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Disk error
repartition ur drive with xp bootable cd...... all data will be lost..
Jan 26, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Open Questions:
See all Western Digital Caviar 40 GB Hard Drive Questions
Western Digital Caviar 40 GB Hard Drive Logo
367 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
