Question about TalkSwitch TS-400 Phone
Somethings wrong! anytime I try to do ANYTHING with my TalkSwitch TS400, it just starts typing FFFFFFFF across the screen... whats up?? H
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Sorry to have to ask all these questions, but they are necessary to try to help figure out what is going on. I need to know what TalkSwitch system model you are using and what version of software it is running. A system serial number is required if I need to contact my distributor. If you could provide the current configuration file on the system, that may help as well.
I am an authorized TalkSwitch Partner and will try to assist you.
Posted on Dec 27, 2007
SOURCE:
How do you fill up your pokedex with a cheat code on pokemon pearl
actually, there are cheat codes. you just have to get a cheap add on called a AR (action replay) card. it costs about 20$ and you can get it at gamestop. once yoou have it, it should have most of the cheat codes and games already on the card. But if it doesnt have the specific cheat code on the ar card then use this
go to the rest of the cheats
press add code
name the code
press ok
then punch in this code- 94000130 fcfb0000
b21c4d28 00000000
b0000004 00000000
e000154c 00000124
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff f0001fff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ffffffff
ffffffff ff001fff
70000000 00000000
00000000 08050000
00000000 00000000
00000000 00032000
00000000 02000000
00000000 08000000
80000000 00800000
20000000 00000080
7fffffff fffffffc
ffffffff 7ffff9ff
ffffffff ffffffff
ffffffff ffffe7ff
ffffffff feffffff
ffffffff efffffff
dfffffff ffffffff
fbffffff 00ffffff
00000000 f0f0ffff
03020100 07060504
0b0a0908 0f0e0d0c
13121110 17161514
1b1a1918 00000000
d2000000 00000000
to activate it press (L+R+Selcect) its ling but it works.... i used to be a huge pokemon fan
Mar 05, 2011 | Nintendo Pokemon Pearl Version for DS
Property Value Manufacturer VIA Technologies, Inc. Product Name KM266APro-835 Version Serial Number Machine Type AT/AT COMPATIBLE Infrared (IR) Supported No DMI System...
Have you tried enabling onboard sound in the bios as previuos owner may have disabled it if they had a sound card installed.The driver is at Via website......
http://www.viaarena.com/Drivers.aspx
Aug 02, 2009 | Biostar M7VIG 400 Motherboard
External caller ID does not display on either line talkswitch 284
Log into your TalkSwitch Management Software.
Go to Telephone Lines.
Under each incoming line make sure that Caller ID is checked.
Click File> Save
Hopefully this will fix it for you.
Jun 18, 2009 | TalkSwitch CT.TS001.124001.US...
Using hyperterminal at commands
you may contact the service provider........
Apr 27, 2009 | Nokia 6120 classic Cellular Phone
TalkSwitch 48 disconnects call after transfer
You are using the wrong option for transfer -- the one you are using is a conference which requires the person transferring the call to stay on the line. You need the option which permits a blind transfer or announced transfer. This issue is specifically discussed in the manual.
Feb 09, 2009 | TalkSwitch CT.TS001.124001.US...
Talkwitch 240VS and TS400 phone
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
May 06, 2008 | TalkSwitch CT.TS001.124001.US...
Wrong region
Hey there, colchester. It appears your daughter, (Blessed be her little angel hands), may have managed to change the setting for TV type from NTSC to PAL, or vice versa. Try entering setup, and using the left arrow, or right arrow, move across the icons on the top of the screen, until you find the box on a plate "TV Type". From here change the type to the other alternate, and you are good to go.. If you still have a problem there is a more in-depth approach if required. Let me know. Good Luck!
Feb 02, 2008 | Digix HT1056A DVD
TalkSwitch TS-400 Phone Logo
163 people viewed this question
Top TalkSwitch Lands Phones Experts
Ekse
Marvin
Marvin
Are you a TalkSwitch Lands Phone Expert? Answer questions, earn points and help others
