Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Dm board mit wd52525
I looked at replacing the P13119 capacitor, but they didn't look bad. There were two capacitors on the power board that did look bad. The number on them was HD420. Does anyone know what these are and if they can be replaced? Where can I find them. DigiKey? Thanks
  • 4,402 Answers
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Posted on Jan 08, 2008
Tv keeps turnig off
You have the V26 chassis with it's notorious problems caused from leaky capacitors. The fix for this is a multitude of capacitors replaced on the DM board, FMT board and the power supply. The right thing to do is to call Mits consumer relations @ 1-800-332-2119 with model, serial and date of purchase and they should be willing to make a concession for discount on a new Mits DLP. That's your best bet. This TV will continue to haunt you otherwise.
Bill W
Mar 13, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Want to replace caps which board is the DM board?
Once you take the shield assembly off, you will see a board, I believe it is the DM Board board. There are four Capacitors grouped together probably rated at 35v 1000 mfd, 105 degree. They should be replaced with 35v 680mfd,105 degree Capacitors. Now once that is done, there is another board under that one. This is the Format Board. It also has 4 Capacitors that should also be replaced. They are the same value as the first Board and should be replaced with the same 35v 680mfd, 105 degree Capacitors.
Please note the Flex connectors at the bottom of the DM and Format Boards. They may not be available from Mitsubishi any more so be gentle with them and make sure the are installed properly when reinstalling the Boards back into the chassis. There is one other Board you should look at. The Power Supply Board is the board on the back of the chassis and also has a number of Capacitors that fail. Most all of the Capacitors that fail through out this chassis will have bulging tops. So any you see bulging, you should replace whether they are on the DM, Format , or Power Supply.
I hope this helps,
Jan 07, 2010 | Mitsubishi WD-52725 52". Rear Projection...
The Capacitors on the DM board need replaceing. The V26 DM repair kit from will usually repair that issue. The kit contains the capacitors and the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green power light blinking all the time on TV
After changing a defective capacitor, my TV still would not power up. After using a solution I found on this site, I held the power and volume up button down on the TV itself for several seconds, the TV powered up normally. I did notice that you had to do this while the timer light was flashing. Doing so after it went out was not effective. I initially only replaced one capacitor which was noticeably defective, and the flashing green timer light eventually returned. I will be replacing all 7 capacitors and resetting the TV. As mentioned above, the capacitors may look good but in fact may be defective. These are high temp caps which breakdown under a load but function normally when cold. Several people have mentioned replacing the capacitors didn't fix the problem. It appears that you must replace and reset using this method to repair some of these TVs.
Jun 06, 2009 | Mitsubishi WS-65615 65" TV
Picture flutters and distorted
Capacitors going bad on your DM or FMT board. Very difficult to replace, but Mits does a rebuild on the chassis. I recommend talking to your Mits service center and getting the rebuild done.
Dec 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing power light tv wont come on mitsubishi 1080
If the tv has the continuous flashing led, you have a DM board problem. It is likely bad capacitors in the DM module.. there are 4 of them 1000uf caps that will go bad. They will get a bulging top on them when they go bad. . Mits recommends replacing them with 680uf caps with a comprable or higher voltage rating. The DM module in on the left side of the set (viewed from the back) and is somewhat difficult to remove.
Dec 03, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Bad Mits capacitors
You can get the full service manual at the following link that will show you how the chassis is removed and then its just reverse the proceedure. Heres the link.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Won't turn on
Do a search and you will find a lot of us that had the same problem. The issue is probably 4 bad capacitors on the DM board. The parts to fix it cost about $2.
There used to be a "how-to" detailing how to do this repair, but I can't find it anymore.
These are the capacitors you need..
part number - P13119-N
get them here..
Mar 29, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS55513 ---Flashing Green LEDs...and now NO POWER.. the entire board / chassis out of the TV shell. Going to start checking individual components, starting with the mail power supply...
start by pulling the DM board (looking from the back it is standing upright on the left side in a metal chassis) and you'll probably find 4 bad capacitors (bulging on the tops is a good indication, If i remember correctly they are near the top right corner)
you can buy replacements here..
Fixed mine this way several months ago..still working like new.
Good luck
Mar 17, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
386 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
