Question about Median M-Cody MX-700 MP3 Player
Accessing the Micro-SD content
How can I access the data on the Micro-SD card? thanks jason.
  • 5 more comments
  • SleepyJay Oct 03, 2007
    Not quite what I was looking for.
    Let me explain:
    There is an expansion port for Micro-SD cards on the player. I can easily access the card through the USB connection through the player (it acts like any USB thumb drive in this way). I also have a USB Micro-SD card reader. So, getting, say, music files onto the card is no problem.
    However, when I try to access those files on the card inside of the player itself, it doesn't seem to read the data on the card.
    I know that my phone also can play music from Micro-SD cards, and in that case, I have to put all of the files in a special folder. I can't tell what folder name, if any, will allow my M-Cody to read the music on the cards.
    Make sense?
    FYI, I bought this in South Korea, so most of the important documentation is written in Korean. I also have the manual in PDF form that may or may not be written in English. For some reason, there is no text written on any of the PDF pages.
    Thoughts?
    thanks
    jason.
  • SleepyJay Oct 04, 2007
    When I try to access those files on the card inside of the player itself, it doesn't seem to read the data on the card.
  • SleepyJay Oct 05, 2007
    This is closer, but still not it. It will be nice to have this manual.
    But I have the 700M, and they only have the manual for the 700. Believe it or not, but the only difference I can see is the Micro-SD slot on the bottom. Thus the manual for the 700 does NOT speak of it, which is my whole problem.
    Sigh. I'm getting worried that I'm running out of options!
    Anyone speak Korean?
    thanks
    jason.
  • SleepyJay Oct 08, 2007
    The manual for the 700 does not have any information about the 700M's feature: the MicroSD card.
    Still looking for a solution!
    thanks
    jason.
  • SleepyJay Oct 09, 2007
    This was a good try, too. The SD card was formatted as plain ol' FAT. I reformatted it as FAT 32, JIC, but still nothing.
    To be honest, I'm not even sure if it's going to show up in "Internal" or "External" and/or if the folders I put on the card are going to show up in the menu, either.
    This is such a cool player, I just which I could get the extra 2GB out of it!!!
    thanks
    jason.
    Wait, this is a little closer...I happen to be able to read Czechoslovakian-or-however-you-spell-it ... no, just kidding...
    But, it says "EXTERNAL: obsah karty Micro SD", which I can only guess means something like "EXTERNAL: access the files from Micro SD".
    So, we're closer. I just can't seem to access any of the content that way. I'll keep pressing buttons and we'll see.
    BTW: do you have any idea why I wouldn't be able to read the pdf supplied on the disk in Adobe? I mean, perhaps it's all in Korean, but maybe it's not. I can't see any character data. I've uploaded it to this web folder: http://www.d20green.com/stuff/
    Thanks
    jason.
  • SleepyJay Oct 10, 2007
    I figured it out everybody... but I'm not happy with the solution.
    So, I think there is a 500 file name limit enforced somehow in the player. I've seen messages pop up about it before, but it didn't occur to me until now that maybe that's the problem.
    All of the music I put on the internal (over 500 files) was showing up fine, and everything that I wanted to do with the player was working just the way I wanted. Except the SD card part.
    So, I just reduced the number of internal files down to fewer than 500. Now I'm going to test if I can put more than 500 TOTAL (between the internal and SD)...
    ... I need to do more tests, but I discovered that putting more than 500 on the SD card makes some of my files disappear. So, either it counts 500 total or 500 on each type of media (internal and external). That kind of stinks. I wonder if there is a firmware fix for that...?
    Anyway, I've pretty much solved my problem on my own.
    Maybe my premium payment can pay for that bucket of ice for SparkGap.
    jason.
The file extensions might be written in another language which you wont be able to access unless you are going to make the xtra effort to change the way xp looks for english extensions
Posted on Oct 10, 2007
  • 363 Answers
You can get an English manual and firmware update here:- http://www.itkorea.com.vn/support/ Regards
Posted on Oct 04, 2007
  • 2 more comments
  • Martin B
    Martin B Oct 09, 2007
    A shot in the dark.
    Is it possible that the SD card has not been formatted correctly?
    Could it be that when the player is being used like a thumb drive it doen't matter about the format but when stand alone it does?
    Check that the card is formatted as FAT32 and not NTFS
  • Martin B
    This is bugging me, but probably not as much as it is you,
    Look at
    http://www.mcody.cz/dnld/mx700mcz.pdf
    It mostly Czechoslovakian or however you spell it but there are english titles and there does in one bit show folders in a browser or navigator from the root.
    I trust your doubt about the model differences but surely its the same as the non-m but the memory is just removable (and bigger).
  • Martin B
    Arrgh the english non-m manual is the same regarding the folders. I'm off to stick my head in a bucket of ice.
  • Martin B
    Martin B Oct 19, 2007
    Jason,
    Could you give one of us the pocket money if you have finished with us?
    Cheers
    President:
  • 2,961 Answers
Assuming you want to access through the player, you may be able to switch storage devices in the settings, connect the unit to a pc via usb and search in my computer in the folder on your player or remove and place in a card reader connected to a pc.
Posted on Oct 03, 2007
Use of storage card
Gordon, Move the stuff on tablet to the SD card to free up space.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Move Android Apps to an SD Card
Galaxy Tab How do move photos videos and other files on my Samsung Galaxy...
internal storage full how to move to SD card
Aug 04, 2016 | Tablets & eReaders
How to save videos to sd card to computer
Have a nice day. My name is adieh.
Using your Samsung galaxy phone you can follow these simple instructions:
1. Attach your digital phone to your PC using a USB cable.
2.Check if your computer recognizes the phone as a memory device by clicking on "My Computer" on you PC. See if it has been assigned a drive letter. This will give you access to the memory on your micro SD card.
3.Drag and drop data to the memory card by clicking on the data and moving it to the drive letter assigned to your phone. You can also right-click on anything you want to save. Click on "Save As" and save the file to the drive.
4.Access the data on your memory card using the "Tools" menu on the phone.
Another option is that if you are using a microd sd card reader. You can follow these steps:
1.Purchase a micro SD card adapter, which will allow you to insert the smaller card into SD card readers and computers. Many of the newer phones come with the adapter.
2. Insert the micro SD card and adapter into the card reader. Make sure your computer recognizes by accessing "My Computer" on your PC and clicking on the drive letter associated with your card reader.
3.Drag and drop videos or other data to the drive containing the micro SD card. Or right-click on anything you want to save, and then click on "Save As." Save the file to the correct drive.
4.Pop the memory card into your digital phone. Access it using the "Tools" menu on the phone.
Hope it helps.
Thank you for using fixya.
Oct 11, 2011 | Samsung Galaxy S GTI9000 Smartphone
Hi larivadances,
Have a nice day.
You can save videos to SD card by following these steps.
Hope it helps.
I have forget my memory card password which use in nokia 2690
If you lose or forget the password for your phone's memory card, there is no way to recover the password or access the data, even by taking your phone to a Nokia Care Point.
However, you may still be able to use the memory card if you can successfully format it. Formatting the card will not work in every case.
Formatting will erase all the data on the card.
To format you memory card:
1) Select Menu>Memory. Your phone shows the details of the memory card.
2) Select Options>Format memory card.
Thanking you
davevipul197
May 11, 2011 | SanDisk 2GB microSD Memory Card
I bought a 2GB micro SD but it is write protected , what can i do please give me reply? Thanks
The adapter that you slide your micro SD card into to access it has a little slide lock on the side of it. 0-hxbuybsb-t555-1122-callout-s-.png
Unfortunately these adapters are notorious for going bad. There are other options you have to acess your data and that is to obtain a micro sd usb adapter. They are much more reliable. Let me know if this helps.
Jan 13, 2011 | SanDisk 2GB microSD Memory Card
I cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device....
i cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device. please help me.
from kapil sharma
Sep 19, 2010 | PNY 2GB microSD Memory Card
Hi this is sanjay , i'm having 1 GB micro sd memory card for my mobile nokia 5300 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in...
The password is there to prevent a thief from accessing the memory card, after stealing either the card or stealing the entire mobile telephone.
Keep trying different passwords.
Oct 22, 2009 | Microsoft Sony VAIO VGN-AR760U/B-Intel...
How do I use the mico sd card on this player?
I would recommend here:
http://www.newegg.com/product/ProductList.aspx?N=2070070068+1053118914&Submit=ENE&SubCategory=68&Tpk=micro%20sd
It honestly doesn't matter what brand of micro SD you stick in your MP3 player, so I wouldn't worry too much. Micro SD's are much smaller, so no, you can't use a normal SD in a Micro slot. Most however do have an SD "shell" that you can stick your Micro into, and use just like a normal SD card. Also I know that MOST mp3 players allow you to add pictures, videos, etc, and having a Micro SD inside should allow you to add things directly onto it, so i dont see why you wouldnt be able to access the contents of the Micro from your MP3.
Hope this helps! :)
May 28, 2009 | Sylvania SMPK8854 Digital Media Player
Micro SD not reading
If you are unable to access/view the contents of the card, chances are, it needs to be reformatted for it to work again, which means, data will be loss. You may, however, try to search the web for a data recovery program which you can first try to use before reformatting the drive.
Feb 17, 2009 | SanDisk 2GB microSD Memory Card
Median M-Cody MX-700 MP3 Player Logo
97 people viewed this question
Top Median Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Median Audio Player and Recorder Expert? Answer questions, earn points and help others
