posted by mumbaixp on Sep 28, 2007
Bad Sector
Solving problem with Fdisk but not success
Other HDD is Not Detecting
other is Taking window XP setup but stop when formatting
2 Other Users Have The Same Problem
Comment by Ansar shaikh, posted on Apr 29, 2008
harddisk Bad sector & not detecting problem
Comment by Guest, posted on Apr 17, 2008
when i copy something from or to the hard drive the computer stope workenk until i rest it
some data from this hard drive i need to copy it and then no problem if the hard drive will dameged
Best Solution
posted on Sep 29, 2007
If your partitioning and/or formatting program is already reporting "bad sectors", then your best bet is to replace the hard drive. The mere presence of bad sectors indicates drive problem which in the normal course of time/usage would increase and eventually make the drive inoperable. Using such a drive as your "C" and/or to contain mission critical files may not be to your advantage.
Hope this be of some idea/help. Good luck and kind regards.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
HP Axiom 60GB for HP Pavillion n5xxx and XHxxx series (AXH2060) Hard Drive
Apple (M9741GA) 400 GB Hard Drive
Buffalo Technology (HD-HB160U2) 160 GB Hard Drive
Buffalo Technology 750GB USB SATA 2.0 HD DS 750 GB Hard Drive
Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive
Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive
Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM 160 GB SATA Hard Drive
Can you Help with these Hard Drives problems?
LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Will not turn on
Will not turn on
My power cord is plugged in,... Answer This...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive
kingston micro sd with adapter
how do i put music into the... Answer This...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB...
Seagate FreeAgent Pro -...
Seagate FreeAgent Pro -... Answer This...
Seagate FreeAgent Go 80 GB USB 2.0 Hard...
usb hard disk no detected
my usb hdd 80GB segate not... Answer This...
LaCie 80GB Mobile Disk USB 2.0 80 GB Hard...
Disconnecting The Mobile Hard...
I just installed a LaCie mobile... Answer This...
Repair Service
Find Hard Drive Repairman Near You:
