I see that you want to uninstall Deep Freeze from you computer, See steps below.
First open Deep Freeze.
On the Deep Freeze window click to select Thawed.
Then Click on Apply and reboot.
Once the system restarts back up you now go to the Add remove programs or programs and feature to uninstall Deep Freeze from your computer.
If you have XP go to control panel then select classic view on the upper left side then look fo Add remove programs then look for Deep Freeze then click on change/remove to uninstall the program.
If you have Vista or Win7 click on Start then control panel look for programs and features, this will show you all the programs you have on teh system just like add remove programs.
Look for Deep Freeze right click on it then left click on uninstall.
I hope that this will help you uninstall your Deep Freeze program from your system.
have u the password for the program? if u have then press CTRL+ALT+SHIFT+F6 at main windows. this will open the deep freeze program. insert the password press OK.
at the deep freeze window there will be option to frozen, thawed, or thawed for next. choose 'thawed' then restart windows.
if you succeed to thawed the deep freeze then find your master program for your deep freeze (master that u use for installation). run the program, there will be choice to uninstall the program. press it. then it will automatically uninstall.
Faronics Deep Freeze is a very powerful application, it prevents any unwanted changes on the system by freezing an entire hard disk or partition without restricting user access. Unlike older version, Deep Freeze 6 cannot be disabled or uninstall this Deep Freeze without password. Before u reformat or install a fresh OS, try the steps below, without password.1. Boot yr PC from the CD with windows XP, if u have Windows XP OS2. Now enter R to repair after booting.3. Let it continue until finish4. Now prepare the DeepFreeze to install, u will come across a option "Uninstall Deep Freeze", select this option and click next. After finishing the uninstall, reboot yr PC. 5. Now u will find that the Deep-freeze has removed from your computer.
If you cannot uninstall the application from "Add/Remove Programs" then you will need to get "Microsoft windows installer Cleanup Utility" from the M/S Website... install that, and remove deep freeze from the list that comes up when you launch the cleanup utility.
To uninstall the software Deep Freeze must first be disabled and then uninstalled. To disable Deep Freeze:
Hold down the shift key and double-click on the Deep Freeze icon.
Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a
password dialog.
Enter your password and click OK. If you have
not yet entered a password you should be able to click OK without
entering anything. You should now see a dialog with boot options.
Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
Locate the installation file you used to install Deep Freeze to this
machine. By default the name of this file is called "DF5Std.exe" for
versions 5.X and "DF6Std.exe" for versions 6.X.
Run the installation file (DF5Std.exe or DF6Std.exe).
Select the option to "Uninstall"
The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
