Motorcycles Logo
D
Doug Courtney Posted on Oct 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Remove carburetors I wanted to clean up the two carbs on my jet ski but the nuts that hold the carbs are almost inaccessable. How do I reach the two nuts on each carb?
paul
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Yamaha Master 1,190 Answers
  • Posted on Dec 28, 2013
paul
Yamaha Master
Level 3:
Renaissance:
Answers
1190
Questions
Helped
263634
Points
1883
Remove air box , cables and pipes ! use and open ended 12mm spanner on the 4 bolts at the base of the carbs and they come off !
5 Related Answers
ginocussen
Gino Cussen
  • 217 Answers
  • Posted on Apr 09, 2009
SOURCE: trouble removing carbs on 96 CBR 600 F3
Theres a big lip holding it. Make sure all cables and pipes/hoses are removed, spray with some WD40 or similar spray lube and then try prying it with something that won't damage the carbs or engine.
Anonymous
  • 190 Answers
  • Posted on May 09, 2009
SOURCE: Cleaning Carb Jets
not to a trained ear also go by rpm and spark plug color
NOTE: use copper wire to clean jets, sync is just thottles are same position as all carb's just leave them adjustments alone will be fine if are out use a 1/8 drill an place in between piston/butterfly to carb bore to sync/calibrate
better use a manometer for adjusting screws
depends on condition of org parts
worn = richer running
new = lean an clean
also if changed the exhaust system need to
re-calibrate carbs for max performance
Anonymous
  • 408 Answers
  • Posted on May 26, 2009
SOURCE: Jet Ski Won't Start when Engine is cold
You must take out completely the carbs and clean them especially their canisters with the flowters.They may have jelled gas inside or closed air pipes.Use a carb cleaner spray and compressed air.
Anonymous
  • Posted on Jul 18, 2009
SOURCE: TTR-125 Won't Start
unscrew the four screws on the bottom of the carb (be ready some gas will drain out) then you will see a goldish looking screw. unscrew it that is your jet
Anonymous
  • 388 Answers
  • Posted on Jan 29, 2010
SOURCE: honda shadow 1100 will not idel unless choke is all the way on
Okay, let me see if I can help you out...it may not be the jets in the carburetor. Hondas, like most other street bikes, have an idle adjust screw on the carburetor. Most times, you can adjust that screw to get your idle at 1000rpm, which is the norm for idle speed.
The screw is not hard to identify; the easiest way is to first, take the air cleaner and intake off. Then watch the carburetor throttle linkage while you twist the throttle. You will see where the throttle cable connects to the carb and there will be a spring-loaded screw right there. Turning that screw adjusts the static (idle) position of the throttle plate; turn the screw so the plate moves in the same direction the throttle cable pulls it.
I'm willing to bet that adjusting this screw will get your idle back to normal. If it doesn't, come back here and let me know; I will then lead you through a procedure to fix the carburetor. Cheers!
1990 ski doo mach 1
You have dirt in the carburetor jets and or passages, clean the fuel tank and rebuild the carb.
Why does my Dewalt d55270 keep shutting off when I take it off choke?
The jets in the carburetor are restricted... remove bowl nut and clean out the carburetor use fine wire to wire out the jets and purge the old gas. Most have honda carbs and the jets are very fine holed and they are threaded into the base of the carb neck ...
Yamaha EF2400is inverter generator, Won't start, I cleaned the carb,put back together, after pulling starter rope checked spark plug, Dry, gas does not reach it?
First of all loosen the nut that holds the bowl on and make sure fuel is getting to the carburetor. If not the hose to the fuel tank is clogged up with setament has to be clean. If fuel is getting to the carburetor there usually a jet that will unscrew inside where the tube that the float bowl nut screws in to. You have to remove the jet and clean the small holes on the side of it and make sure the middle hole is clear.
Where do I put the carbeurator gaskets on husqvarna5521?
this link shows how to rebuild a carb. I suggest cleaning the jets before you try anything else, if you havent done so already. At the bottom of the carb there is a not that holds the bowl in place. Remove yhe nut and bowl. In the nut there are tiny holes, clean them out using a wire (bread tie will work) you can also use an air compressor, A shot of carb cleaner wont hurt. More often than not this is the cause of most small engine issues. How to Fix Lawn Mower Carburetor eReplacementParts com
Help!! '97 Seadoo GTI, just had the carburetor rebuild, replaced the Rectifier Regulator, replaced the spark plugs and recharged the battery. But the jet ski would only reach 40mph and it would bog down to...
Sounds like you might have the rotary valve in the wrong position. Also you are going to need to replace your fuel lines and check the fuel petcock for any blockage. Lastly, when u rebuilt this carb did you check the tiny fuel filter behind the pump body?
3answers
I need to clean carburetor on 340gx honda pressure washer. How would I do this?
pour large amounts of liquid carb cleaner into the gas tank
Let it run for a couple of minutes then shut it off and let it sit for a couple of days.
I have a 1994 Polaris jet ski slt 750 that will start up when it's out of the water but when I put it in the water it won't start. It just started doing this. I had the battery checked and was told it was...
You are deal with moisture corrosion in your carburetor. Take the carb off and clean it paying attention to the corrosion on the rubber tipped needle. Also open your electronics box and make sure that it is dry.
Hello i have a jet ski seadoo 95 gtx when i pull on gas all the way it chocks out on me wat i nedd to do thank you
You are probably dealing with moisture corrosion in the carburetor. Take out the carb and carefully clean it. Paying close attention to the needle. Be careful not to alter the spring on the needle in any way.
No fuel is getting to the carb,
The two fuel pumps are mounted on the individual carburetors and are operated by crankcase vacuum. Typically if the carburetors are not getting fuel it is the fault of moisture corrosion on the needles inside the carburetors that open and close with the pulses to feed fuel to the jets. A thorough carb cleaning should fix the problem.
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
