SOURCE: transmission problems (gear linkage)
The gear linkages are not correctly aligned.
Is the gearbox mounting in exactly the same place as when you removed it?
Even a 1/4 inch will offset the gears.
hope this helps
SOURCE: my 92 honda accord will not go into 1st 3rd or 5th gear
check shift fork adjustment. make sure you bleed the slave cylinder.also check shift cable adjustment.
SOURCE: 4l60e slips in 3rd and 4th
There are to many things that can cause this problem, best thing to is go get the ECM scanned for DTC codes at a transmission shop or Auto zone or Parts Source since they scan for free.
The ECM should have DTC code in it's memory on how the transmission is Performing and have the Transmission line tested for Fluid pressure.
Good luck and hope this helps. Oh and also ways check with more then on transmission shop if there tell you that you need a new Transmission,
It could be a simple as the transmission filter falling off causing the lost of transmission fluid pressure. Check the transmission fluid too.
SOURCE: 1995 Sabb 900 clutch wont engege in reverse
Bad syncro for third gear. Sorry, but you aren't fixing this one yourself, unless you replace the transmission yourself.
