Question about Jenn-Air JJW7530DDS Electric Single Oven
Jenn-Air w156 Single Wall Oven Problem
This is an Electronic Jenn air oven that dates back to the early 1990's. It will not stay on. When I press the electronic controls to bake the oven will only stay on a few seconds and then goes off. When I press the electronic controls to broil the same thing happens. When I press the electronic controls for the clean setting it too goes off after a few seconds. (few seconds is around 10-15 for all scenarios.) Same thing also in the convection bake setting. Also under all cases I have felt the bake element and or broiler element after the the oven goes off after the few seconds and there is no signs of heat at all.
  • tvalenti Dec 19, 2007
    My oven is on its 2nd circuit board and this one has been dying for about the last year. Symptoms are the same as last time. Display blanks out due to heat of cooking and then comes back after oven cools off. Over time the board starts to lose time, lose temperature and then eventually the entire display goes dark and doesn't come back. Jenn air evidently does not want to solve the problem by using a more robust circuit board, so we have decided to dump the POS and buy another oven from a different manufacturer. I will not invest in Jenn air again, all looks and no longivity.
    This is a manufacturing (design) defect and if they want to keep customers they should provide an alternative, more robust pc board. At the least they should provide the replacement circuit board at low cost. It is just a stupid pc board with nothing more advanced than a wall thermostat. My latest estimate was $500 to replace it. No thanks. Good riddance Jenn air.
  • Anonymous Mar 19, 2008
    i have the same problems the oven is in great and is still very clean has new seals new thermostat but the problem is same
  • 447 Answers
Most likely its the EOC (electronic oven control), it needs to be replaced. If you self cleaned the oven a lot the very high heat generated fatigues computers in modern ovens.
Posted on Sep 28, 2007
What does F1 mean on my oven
F1 code for Jenn Air is related to the main electronic control board. If you can turn your breaker off for a few minutes then back on it may reset. If not you will most likely need a new control board. Depending on your model number and age there may be extended warranty on the parts, check with Jenn Air to be sure
Apr 24, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Error message on JJW9530DDS Jenn-air wall oven is 4d21
no/low cooling fan rotation (No RPM) single cavity or upper oven - check connection at cooling fan if ok, replace blower - DO NOT REPLACE CONTROL
Mar 06, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
7 yr old jenn-air wall oven locked shut, shut down
It will remain locked until the temperature is safely as low as it should be. You just have to wait and be patient.
Jan 31, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-Air wall oven control panel not working
my jenn air wall oven controls are not working how do i fix it
Nov 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn-air w156, displays f1 fault code. how do i
This is a Defective touch pad or membrane
Replace touch pad or membrane (this problem is usually the touch pad)
Jun 17, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
WW30430
lower oven gives Fr code when turned on
Jun 23, 2008 | Jenn-Air JJW8527C Expressions Collection...
Jenn-Air single electric wall oven #JJW9530DDS
try to open the door see if the door latch is extended if it is locate the light switch on the oven cavity and hold it in then hit start then cancel or stop the latch rod should go back
Dec 27, 2007 | Jenn-Air JJW9530C Expressions Collection...
Jenn-Air JJW7530DDS Electric Single Oven Logo
683 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
