Question about Philips Magnavox 27MS343S 27" TV
Magnavox television The parential channel lock out was activated on our television.The person who activated this feature is not avaiable to speak with. Is there a master code for this ,so we can disable this function ? Thank You please note, the product window below this is not the correct one. The model # is : 27mt3305
  • KEVIN2894 Feb 09, 2008
    HOW DO YOU changing the memory -eeprom
The easy way is changing the memory -eeprom-
Posted on Sep 29, 2007
SOURCE:
I need to know how to unlock my magnavox ZV427MG9 I've been looking for awhile now but it seems like the code is un breakable if I could please get some help that will be fully appreciated. Thank u.
Hello
If you did forget the parential password to this set, come to parential lock menu, and enter digits 4,7,3,7 . The set password will be cleared. For more details, go tis user manual page [EN 73]. If you don't have a user manual to this device with you now, inform me, by Fixya comment box, along with the your email address. I've the user manual to your device, and I'll send a copy of it to you by return mail. Try these links to download the user manual to your device.
http://www.manualowl.com/p/Magnavox/ZV427MG9/Manual/55272
http://www.dataentryjobs.us/67948.html
http://img.almo.com/_Assets/Magnavox/PDF/ZV427MG9-Manual.pdf
http://www.manualnguide.com/download/manual-guide/magnavox-zv427mg9-owners-manual.html
Feb 29, 2012 | Televison & Video
It is on retail store mode - how do i get it off this
Hello
Surf throug its menu options and come to parential control window. The parential contro default code is 0711. There you can see the option "Reset". Select it, and press enter. All the channels and programmes will be reset to Factory settings. you can adjust allthe settings according to your taste later. OK.
Mar 19, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I have no volume on certain channels
The most common problem with no volume only on certain channels is the TV is programmed for 2nd Audio, also referred to as SAP which is a feature activated to transmit a second language such as Spanish. If you push your menu button on your remote control you can toggle over to Audio Menu. Then find the feature that allows you to adjust the sound for Mono, Stereo or 2nd Audio (SAP). Adjust the menu to highlight Stereo and that should cure your problem.
Hope this helps with your particular problem.
Dec 05, 2010 | Philips Magnavox 42MF521D/37 Television
Cant attain digital channel scan on hitachi rear projection tv
Do you have the tuner locked out for use of HDMI input only?
Most of the time when a selection is not able to be hi-lited it is
because a feature that is activated locks out other selections.
Hope this helps,
Skyassoc
Jun 17, 2009 | Hitachi 51F59 51" HDTV Projection...
Can,t remember parential block code
In the setup part for parental control, when it asks for the password..enter 0711 ( twice ) it will probably say incorrect password after the first attempt, do it again....This is the default code and sequence for Philips/Magnavox in 90% of there sets. Let me know and good luck.
Feb 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
We have a magnavok big screen tv
Manual Library you should find all you need here:
http://www.techlore.com/group/2/list_downloads
Hope that helps, good luck
ALSO:
I searched a Magnavox manual for the lock feature here is what I found...
The following functions are disabled during SDM (and enabled after leaving SDM):
· Parental lock
· Blue mute
· Hospitality Mode
· No-ident Timer (normally the set is automatically switched off when no video signal (IDENT) is received for
15 minutes).
All other controls operate normally.
Entering Service Default Mode
To enter the Service Default Mode, press the following key sequence on the remote control transmitter:
0-6-2-5-9-6-MENU
Do not allow the display to time out between entries while keying the sequence.
Upon entry into the Service Default Mode, the letters “SDM” will be displayed at the upper right corner of the screen.
ALSO:
- Line 7 : “CHANNEL BLOCKED”
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Sep 07, 2008 | Philips Magnavox 51MP392H Rear Projection...
Can't get the tv to move from the cable mode
Wondering if this is what your asking about, I cant find reference to Cable only mode...
Set to “OFF”
Aug 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
[email protected]
Nov 17, 2007 | Philips Magnavox MS3652S 36" TV
Acess code
Try activating demo mode--ON==hold both vol up and chan up on front of set for four seconds, then do same again==did it clear code lock? Let me know if you need more help.
Sep 30, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 27MS343S 27" TV Logo
85 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
