Water Heaters Logo
J
James Posted on Oct 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
"I have a Rheem rheem gas furnace model rcfl-hm4821cc, only a few years old. It was working for several days at beginning of heating season, then abruptly quit. It appears to be trying to cycle through the startup process, with the igniter sparking, then quits. Any idea about what could be wrong?
RJ Systems (Retired)
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 215 Answers
  • Posted on Dec 13, 2013
Expert
Level 2:
Mentor:
Answers
215
Questions
0
Helped
60818
Points
321
If you get no pilot at all, check to see if any gas is getting through the pilot assembly. Try a very long match or butane fire place igniter while it is sparking.
1 Related Answer
Anonymous
  • Posted on Feb 04, 2011
SOURCE: RHEEM 40 GAL ELEC TALL Water Heater 6YR SC 82VH402: my rheem 81sv40d water heater quit heating water. ...
I have the same problem about every 3-4 months. Mine is also about 10 or 11. It is usually the sediment at the bottom that causes this. Once the plumber flushes it, it works again. My problem is that I dont know how he did it and the vavle is at the floor level. I am never home when it is repaired. Regular maintenance (flushing) is how you avoid this from reoccurring. That is, if that is the cause of your issue.
Rheem furnace error code 68
Rheem furnace error code 68 is a mechanical relay system which signals the blower motor to stop because it has not received a signal from the thermocouple.
Jul 20, 2022
Rheem furnace error code 68 - HVAC Contractors
Motor Power And Communications Issues (Fault Code "68")
ManualsLib https://www.manualslib.com > Rheem-96v-Series
Motor Power And Communications Issues (Fault Code "68"); Line Voltage And Low Voltage Connections To The Communicating Motor - Illustrations - Rheem 96V Series ...
2helpful
2answers
I have Rheem Pvw50, 50 gallon water heater installed at home. For the past few days, there is a noise coming out of blower motor. What could be the reason?
Your water heat is at an age that I would recommend replacing the whole unit. That one cannot be too efficient and most likely has sediment built up on the bottom of it pretty bad.
How Do I restart the rheem 81v30d
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-light-gas-water-heater.html
Rheem does not post service manuals.
One reason is that water heaters have changed rapidly last few years, and same model might have different features because Rheem experiments to see which products work after they are sold.
Calls to Rheem for DIY help are largely useless since they want you to call local installer or technician... who will sell you a new heater for more money.
Rheem wants to end DIY repairs since doing it yourself saves you money... which means Rheem, and Rheem-loyal service companies make less money.
http://waterheatertimer.org/Which-is-best-gas-water-heater.html
http://waterheatertimer.org/New-government-water-heater-standards.html
Gene
New government water heater standards
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I just had my furnace cleaned it is a gas rheem. The service guy said it was overheated because of a#3 tube he said the furnace heat exchange is black. What can be do regarding this
I presume you're talking about a gas furnace, even tho the title says Rheem gas water heater. Either way, it works the same for both.
Any black coloring on the heat exchanger is *not* from overheating. Black is from a sooty flame caused by a mis-adjusted burner. (In fact, a sooty flame is less hot). There is an adjustable "air intake plate" for air to enter the burner where the gas enters the burner. A proper flame is made by adjusting this air opening so the proper gas/air mixture feeds into the burner. If the air vent is closed too much it produces a sooty flame.
The age of the furnace is the most important aspect, and that helpful to determine a likely condition of the heat exchanger and burners. Other than a badly adjusted flame, the main thing to watch for is a badly rusted out heat exchanger. But black does not mean rust.
Rheem rtg-53pvn will not turn on and heat water when hot water is turned on - no error code - remote just goes off like the power is off
Before calling service technician, open following link for Rheem troubleshooting resources including Rheem chat:
Rheem will suggest you catch up on required yearly maintenance which would cover most causes for common error codes, and cover cause of no error code including plumbing problem or loose wire or PC board failure. Combination of problems can also cause failure and these issues would be covered by general maintenance.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Solve most tankless problems same day for $350
http://waterheatertimer.org/How-to-install-gas-water-heater.html
BOUGHT THE UNIT IN JULY 2009 WORKED FINE UP UNTIL THREE DAYS AGO WHEN I RUN THE HOT WATER IT RUNS FOR A FEW MINUTES THEN SHUTS OFF.
1) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
http://www.rheem.com/hrc.aspx
2) Call local service technician, and put that person in your rolodex-wallet for future help.
Ask technician for tips and tricks for keeping unit working and needed maintenance.
They will gladly offer a yearly service.
3) Read manual several times to get accustom to yearly maintenance required for tankless water heaters. Tankless water heaters are maintenance heavy. All costs are energy.
4) Read manual several times and notice word troubleshoot appears many times.
Since tankless are complicated machines, many internal and external factors can affect operation, especially as unit ages.
5) Look at label on unit to identify exact product number. Identify same/similar product at Rheem, and become familiar with Rheem website
6) Read other question/answers at fixya about Rheem tankless to become familiar with the tankless era
http://www.fixya.com/tags/rtg_74pvn
7) Install DIY tank-type gas water heater and avoid the whole headache
8) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Rheem natural gas water heater installed about 5 years ago has begun to fail every 4 days or so it needs to be re-ignited manually. Works fine again for several days but inevitably will cease again heating...
Well you might have a pinhole leak than periodically puts out pilot light. Or you might have a bad thermocouple. Thermocouple is inexpensive and easy replacement.
3helpful
How can I get a manual for my Rheem Gas Furnace
Contact Paloma/Rheem customer (800-432-8373) support and tell them what you have; they'll send you the documentation - by regular/email.
Happy Holidays;]
JZ...
3helpful
2answers
Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
Top Water Heaters Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Water Heater Expert? Answer questions, earn points and help others
