SOURCE: reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
SOURCE: hello,my reebok i-run treadmill belt is not moving
Usually a spark means you have a problem with either the drive motor or motor controller board became damaged. Unplug unit remove the motor shroud physically inspect the motor and board for any signs of arching then replaced the board. Next use a multi meter to check continuity of the drive motor by removing the red and black leads that attached to the board if a reading is much more than 1.0 to 2.0 ohms then your motor is also damaged need to be replaced.
SOURCE: How do I oil my Reebok i-run treadmill?
I have a problem with my reebok i walk i run treadmill. The belt does not move on the lower speeds and after using it there is a burning smell even though it is working fine once I get past the first two speeds. I have had it 2 years but have never oiled it as I am not sure how and where.
