Question about HP Compaq Presario V2000 Notebook
DVD cdrom doesnt read any cds dvds audio cds
Compaq v2000 with win xp and a amdTurion64
    Sergeant:
  • 457 Answers
The Rom may need cleaning. There are two diamond heads in the rom one to read DVD and the other to read CD. The CD one is most likely dirty try cleaning it else its faulty and needs to be replaced.
Posted on Sep 28, 2007
SOURCE:
Need help with Compaq Presario v2000 drivers
Your DVD drive is missing the Burning Program not the driver. I found an update for your windvd software for windows 7 but you probably have to have the full program installed to run the update. Hope this helps.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=432985&prodNameId=500746&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ob-26952-1
Jan 10, 2010 | HP Compaq Presario V2000 Notebook
Cds will play but not dvds
Make sure you have a dvd player installed. If you do and dvds still will not play then that means that your dvd drive is bad and would need to be replaced.
Dec 18, 2009 | HP Compaq Presario V2000 Notebook
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
Laptop CD/DVD drive Can't read cd/dvd
Try cleaning the DVD with a CD drive cleaning disk.
Jun 28, 2009 | Compaq Computers & Internet
Cdrom doesnt recognise blank dvd. error message
Its only cd writer burner and can only that it can read dvd disc also. That is why its called combo. But burning blank dvd it can't. But if you want buy some dvdburner too.
Apr 19, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Laptop dvd not working but will play audio cd's , ive cleaned it, downloaded xp codes and still no luck. the laptop still sends message that no disc in serted. can anyone help. it is a compaq presario...
Reading or writing DVDs is much more demanding on accuracy than CDs and even a small drift in tracking can create the situation you have. The ratio of content is about 6 or 7:1
If cleaning has not helped (as is often the case), replacing the drive may be your only choice.
Mar 29, 2008 | Computers & Internet
DVDRW will not read CDs
1)right clik on my computer
go to
properties
device manager
clik on cdrom
uninstall it then re-install it
after reinstall try using the drive
2)update windows ,use custom and see if it finds an updated driver,if it does or doesnt update windows anyhow.
after you restart the computer try using the rom drive.
if that doesnt work;
go buy a cd/dvd rom cleaning disk at your local electronics store and use it.
if all this doesnt work;
buy a new rom drive
Dec 08, 2007 | Computers & Internet
Dvd troubleshoot
====================== If you are having trouble with Newly bought items save your self from headaches by returning them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Sep 16, 2007 | Optorite (dd0405) DVD±RW Burner
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Mar 07, 2007 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
HP Compaq Presario V2000 Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
