Question about Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 not distributing shampoo...
My kirby usually works really well, however sometimes the shampooer doesn't lay the foam out when I try to shampoo the carpet. I clean the shampooer everytime I use it, before and after. Sometimes, it just doesn't work. Then the next time I use it, it's fine. I hadn't had the problem in a while until just now. I can see the shampoo/water in the clear hose and it is moving very slowly. Hardly anything is getting to the carpet. Any suggestions?..truly I have cleaned it...
  • colley411 Oct 16, 2007
    I checked and the screen is there, nice and snug.  I also make sure that stays clean.  It's weird because SOMETIMES it works and then I do nothing different and then it doesn't work.  Same thing the other way around.
    Thanks for your idea though!
Thanks kathy, that's exactly what my problem was, the screen was stuck in the hose.
Susan
Posted on Oct 20, 2007
 I was having the same problem. There is a filter plug that came loose on mine and went down into the hose. It belong on the water tank and fits in there tightly and the hose end goes over it. That's what actually makes the foam.
Thanks again! Kathy
  • 357 Answers
You are missing the wee round suds screen that goes over the hole where the hose attaches to the tank. It may be wedged in your hose.
Posted on Oct 16, 2007
  • Marci Marple
    Marci Marple Dec 05, 2007
    That's what I said......lol
    Marci
SOURCE:
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Feb 14, 2015 | Kirby Ultimate G Bagged Upright Vacuum
Can i use a different cleaner in my kirby shampooer
Yes as long. As it Is a foaming shampoo. Do not use extractor detergent
Aug 01, 2014 | Kirby Ultimate G Bagged Upright Vacuum
Shampooer does not distribute foam
It usually means you have no filter or a defective filter in your shampooer hose,or your not using kirby shampoo.
Dec 09, 2011 | Kirby G6 Bagged Upright Vacuum
Kirby G3 shampooer
The Kirby shampoer lays a layer of dry foam on the surface of the carpet and then scrubs it back off with a rotating brushroller. You can get more details of how to use one here...
Here is a step-by-step guide to help you out!!
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Hope this helps,
Marci
Jun 21, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby vacuum with the shampooing attachment. The shampoo/liquid comes out of the shampooer in a drizzle of liquid. There is no foam.
You need to check that the little round screen is in the hole where the hose attaches to the shampoo tank. My guess is that the little round screen is wedged sideways in the end of the hose. Here is a guide to help you further... http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Jun 01, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Dry Foam Shampooing
Here's my online guide for using the Kirby shampooer....
http://reviews.ebay.com/KIRBY-CARPET-SHA...
HOPE IT HELPS!!
Marci
Nov 23, 2007 | Vacuums
Kirby Ultimate G Bagged Upright Vacuum Logo
155 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
