How do I remove write protection from USB flash drive?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
How do I unlock an encrypted flash drive?"); display: inline-block; height: 24px; width: 24px; margin-top: -1px;">
Hi, try these default Security Codes: 12345, 0000. If you have changed the default password then I suggest that you to flash the Cellphone by taking it to any Mobile Service Center. Flashing the Cellphone will reinstall all the software of the Cellphone including the Operating System. Hence bypassing the security code issue.
You can create a Windows password reset bootable CD/DVD or USB flash drive to reset forgotten Windows password, i have created a bootable USB flash drive with the tool Windows Password Breaker and reset my administrator password successfully.
Forgot Windows password?
Of course, you canuse Windows Password Unlocker to create a password reset disk with a CD/DVD orUSB flash drive. But what you do firstly is to find an accessible PC with a driverand a writable CD/DVD or USB drive. Then you can follow the steps below to burna password reset CD or USB flash drive.
Step 1: Download WindowsPassword Unlocker
Step 2: Install theprogram and open it.
Step 3: Burn apassword reset disk with CD/DVD or USB drive
Step 4: Reset lost passwordwith the burned CD/DVD or USB drive
Note: There are 3versions of Windows Password Unlocker. Just select one of the version suits youbest.
It is very easy andit takes you less than 5 minutes. Good luck!
1.Insert card into your phone but don't access it through phone.
2.Run FExplorer and Open the path C:\system.
3.You will find a file called mmcstore ,rename the file mmcstore.txt
4.Copy that file(mmcstore.txt) to your pc and open that file in notepad.
5.You will find your password in that file.
You can find the FExplorer from the internet..
My drive became locked with a password or I forgot my hard drive password. How do I gain access to my data?
Answers from Hitachi : Unfortunately, there is no way to bypass the security password feature of Hitachi hard disk drives. If the password is not known or has been misplaced, Hitachi will not be able to assist in gaining access to the data on the drive.
If you have a write-protected flash drive that you need to access, it can be difficult to change it to allow you access, especially if it is a security-optimized flash drive. However, there are a few practical steps you can take to change the write-protection on a flash drive.
#1
Check for a write-protection switch. This switch, when engaged, will lock the contents of the flash drive and is a very common security feature. It is generally located on the side of the flash drive, and has an "enabled" or "on" position, and an "off" position. Slide this into the "off" position.
#2
Override password security. If your flash drive has password security, but you have forgotten the code, you can try to override the security feature by going to the Start menu and selecting "Run." A dialogue box will pop up, into which you should type in the path to the file on the USB drive you want to access. Note: This only works on USB drives with very simple security. If the security is complex, this will not work.
#3
Format the flash drive. If nothing else works, you can always format your USB flash drive, which will set all your write protections back to default. From there, you can customize them however you want, but all your data will be lost. To format the flash drive, go to the My Computer, right-click your drive and select "Format." A status bar will pop up. Once the status bar disappears, you can change the write-protection settings on your flash drive without incident.
Passwords are ment to keep your data secure.It's not easy to get arround.There are data recovery services that can recover data,their not cheap.Some software programs you can buy that recover data can also recover non encripted passwords.Good Luck.
