Question about Epson Stylus C84 InkJet Printer
White lines appear in printing
Every 6 to 8 lines a white or blank line appears through the font. I have printed the same letter 6 times (after doing all the cleaning and aligning shown, wiping rollers with clean soft brush, and restarting laptop and printer) and the lines always appear at the exact same place no matter what I do.
  • Anonymous Nov 01, 2007
    white lines run through printing
  • Epson Master
  • 705 Answers
Try changing the driver settings to a higher or lower quality output. If the problem changes it would suggest that the alignment is till not quite right. This sounds like a BiDirectional mis-alignment issue. You could also try my under head cleaning routine, which is cheap and easy and solves many problems. Review my previous post about cleaning HERE -> http://www.fixya.com/support/t137335-problem_print_outs_from_printer
Posted on Sep 28, 2007
My Dell 1720dn mono laser printer has not printed properly for some time - in fact it's dreadful! The letters and dark images have white vertical lines going through them, and some of the printing do
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dec 05, 2014 | Dell 1720dn Laser Printer
A blank vertical line appears on every page printed
if it is a white void check laser shield glass. toner might be on it causing this problem. There should be a wand in front door use to clean laser area make sure you do each color. hope this helps.
Feb 09, 2014 | Ricoh Aficio CL3000 Laser Printer
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
I have a Epson stylus the print has white lines on the letters as well as the photos. i have cleaned done head cleaning several times alignment no use it still prints the same
It seems that the print head is clogged.
You can choose to live with it by print at slowest speed (best photo or things like that) Or you may try to fix, however, it requires some skills.
A. USING ALCOHOL
1. Check if what print head was clogged: Print a test page. 2. Look at the test page, identify incomplete lines. what are there colors? For instant, blue line: clogged on blue head 3. Remove the ink tanks, and pump alcohol through the clogged print head 4. Do head cleaning to see if it works
If it does not work, try B method. Please only do this if you have experience on disassemble a printer, or you have nothing to lose, because incorrect handling parts from printers will kill it forever.
B. DIPPING THE PRINT HEAD IN BOILING WATER
1. Remove the ink tanks,. 2. Remove all the cables connect to cartridge 3. Remove the cartridge 4. Boil some pure water ( Aquafina of Pepsi is the best) until small bubbles appear 5. Dip the head of cartridge ONLY in boiling water for 2 minutes. 6. Put all things together.
Mar 26, 2011 | Office Equipment & Supplies
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
When I type a letter it appears as two vertical lines but no letter
The hammer has two vertical pieces at the front, meant to strike the print wheel.
Do you have a font wheel in it?
Jul 14, 2008 | Smith Corona Wordsmith 200 Typewriter
Problem Printing word documents
yes..I agree...that line through the letters sounds like something from the font settings in word...do you have True type fonts selected? The landscape issues sound odd too, but I'm sure it's on the word settings side, not the printer.
check your computers warranty here 4 FREE
Mar 11, 2008 | Dell 922 All-In-One InkJet Printer
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
6,217 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
