Question about Toshiba 32A43 32" TV
My bush tv idlcd32tv22hd
Hi, Pls help fix my tv, What happened was i was watching a movie and i want to increase the volume and i mistakenly pressed the menu botton and the menu came on as if i want to change the contrast, i waited some second for it to go off and i was impatient i had to press a button and since the the tv sreen went blank not showing anything no the volume working. But the lightis on showing that there is power supply to the tv. Pls kindly help me out.
  • 1 more comment
  • Anonymous Feb 16, 2008
    Exactly the same problem, will not respond to buttons on side or remote control
  • Anonymous Feb 27, 2008
    Power supply part number 17PW15-8 is required. About £50. Fixes it up nicely.
  • Jim Cotterill Jul 02, 2008
    I have same Bush tv, was watching in the morning, turned off tv, went to switch it on in the afternoon, red light comes on, press button on remote and green light comes on, then I get csreen for 1 sec and then it switches itself back onto standby.
    Brigadier General:
  • 6,966 Answers
Hi, You can try resetting the TV. In some other brands/models, hard reset is done by unplugging the TV from the mains for a couple of hours. Preferably check your owner's manual for more specific instructions. Good luck and kind regards.
Posted on Sep 29, 2007
6ya staff
SOURCE:
The sound goes on and of when watching a movie
see the cause and fix it: God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Wharfedale DVD-M3 DVD Player
Hi, i have a Denon PMA 735 R amplifier which shuts down when volume increases suddenly.
Sounds like you have output transistor problems. Does it have a red protection light that comes on when it shuts down? If it does it will need serviced.
Dec 06, 2011 | Audio Players & Recorders
I increase all the volume on the tv to watch regular tv and the sound is very low but to watch movies on the dvd is fine, what could be the problem? thanks
If you get your tv through some kind of set-top-box (if you have cable or satellite tv for instance) the STB (set-top-box) may have it's own volume control that is set to a low level. You will have to look through "settings" on your STB.
Mar 14, 2011 | Panasonic Televison & Video
My vizio tv is making a buzzing noise when I watch tv.. I tried turning the volume up on the cable box up and the volume on the tv down but it didn't help.. It's still making that noise.. This doesn't...
Hi, Mary with Dish Network Customer Service. I had this issue with my TV as well. You will need to turn the TV volume up and the cable volume down. The opposite way from how you have it now. This should resolve your issue.
Jan 24, 2011 | Televison & Video
Whenever I am watching a movie or playing a game and there is a sudden increase in volume (such as an explosion) the volume lowers suddenly to "normalize" it. After a few seconds it returns back to normal...
Hi Metallica309
A lot of flat screens have pretty over-reactive 'normalising' controls. I have a Wharfedale flat-screen which 'compresses' any extra sound to the point where it's impossible to understand speech.
Start by hitting 'Menu' on the tv - then select 'Sound' - then lookout for AVL (Auto Volume Level) or 'Normalise'. DESELECT the AVL.
O.K. - so it's going to sound louder for explosions and quieter for whispers - but that's what real life is really like !
You may have similar settings hidden away on your other devices - do the same with them. The cumulative effect of a string of devices (all with AVL on) leads to auto audio mayhem.
Try it - and good luck.
Aug 10, 2010 | Televison & Video
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Mar 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
Problem wit audio
Hi
What do you mean the sound is?
Apr 18, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Wish to use extension speakers with Bush IDLCD32TV22HD
You will need to get into menu and enable the external speakers. Some older TV may have a switch at the back to turn the external speakers ON.
Feb 25, 2008 | Televison & Video
Not able to record sound
Hi '
Try check the volume control maybe on low volume or in mute, If in mute select off increase thje volume and ok.
Oct 10, 2007 | Canon PowerShot A520 Digital Camera
Philips 27PS55S/121 sound level decreases
Yes, the dynamic range on DVD's is enough to cause the high and low passages to be somewhat annoying but, sounds more like a movie theater. This kind of dynamic range showed up first on Beta HiFi and VHS HiFi VCR's because of thier range as well. If there is a feature in your audio menus on your TV such as "audio expansion, SRS, Wide mode, etc." turn it off and let the audio be processed without expansion of any kind as that will amplify your dynamic range alot more. The lock up issue could be something Philips is aware about and if under warranty contact them. Otherwise not much you can do except manke sure the voltage going to the TV is failry stable between 110 volts and 120 volts. Sometimes dramatic drops and or increases can cause lock up or confusion to the microprocessor in the TV.
Mar 25, 2007 | Philips 27PS55S 27" TV
Toshiba 32A43 32" TV Logo
670 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
