Question about Westinghouse WST3504 Microwave Oven
Suggestions mine is SHARP macrowave 17 kgs,actually our macrowave for some time when pressing buttons it responds,then again pressing after sometime it dont even respond.But the current(power) passes through it and light also comes inside the microwave,but it doesnt work.Do u have any suggestions
  • Anonymous Feb 28, 2008
    setting the clock
    Champion:
  • 225 Answers
Check the touch pad or control switches, and check the control panel circuit, check the thermal sensors. check the wiring.
Posted on Sep 29, 2007
SOURCE:
The keypad on my sharp microwave model R-953 (SL) M is not working. Anything I press on the keypad does not respond, but the light comes up whenever I open the door. It works well till 2days ago.
it could be any number of things . usually taking it into a repair shop and having it checked is only way to know for sure and get estimated repair cost .Mine was the door switch and cost 50.00 for them to repair .
Sep 20, 2015 | Sharp Microwave Ovens
Clock will not set time
Most microwaves just need to have the clock button pressed 1 time. Then you enter the time. Next some want to to pick am or pm. Then press clock again to set. Sometime last step is the start button instead of clock.
Mar 02, 2015 | Kenmore Elite White 1.5 Cu. Ft. Convection...
Convection oven shuts off after a minute when trying to bake. Does this during Compubake also.. Does not preheat
Possibly a bad oven temp sensor. If the uinit doesnt read a temperature it will shut down to prevent a fire or over heating. The temp sensor is a thermister A temperature variable resistor that changes value as the temp changes. so If the main board doesnt get a response within a vertain resistance range it shuts things down. Sometimes since those parts are in the actual cooking area and subject to the heat and steam from cooking they can rust and break, or just get old and break. Or slam the door and break, you get the idea!!
Oct 19, 2017 | Sharp R-1874 Convection/Microwave Oven
Answer call sound
I think you have food splater on the plate. It is possible to remove it and carefully wipe both sides clean. Make sure it is thoroughly dry before replacing. I left mine to dry most of the day on a sunny window ledge before replacing. Have had no sparking since I did this.
Sep 25, 2013 | Microwave Ovens
I have a Shapr Microwave Convection model R-8880(W) T which is flashing after being stored for 3 months. It won't work, the timing light just keeps flashing on andoff 88-888. Does it have a reset...
Try pushing / stop reset first. The setting the time by pushing clock button .... punch in the time and push the clock button again. Just respond here if that does not work. 88-8888 is what you get after your first plug it in. Sometimes you will get PF if you unplug it and plug it back in. If that appears push stop / reset / clear. (Same button)
Kelly
Dec 26, 2010 | Sharp Microwave Ovens
Wont work
Don't know this particular model, but it sounds like you are just pressing the time buttons for cooking and not actually setting the time clock which is what it's asking for. Are you following the instructions for setting time as detailed in your instruction book?
Oct 20, 2009 | Whirlpool Microwave Ovens
POSSESSED MICROWAVE!
wow.......... an exorcism may be in order.......Sadly your microwave circuitry is malfunctioning which is a costly repair. I would seriously consider trashing that possessed unit and purchasing a new one. the new ones are greener too, use quite a bit less electricity
Jul 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No numbered touch pad for use setting clock
I think on this one you press the CLOCK/TIMER pad, then enter the desired time using the 10 MINUTES, 1 MINUTE, AND 15 SECONDS pads then press CLOCK/TIMER again.
If that doesn;t work, press STOP / CLEAR then try the above again.
Let us know if it does not work.
Mar 05, 2009 | Sharp Microwave Ovens
Sharp R-402JKF microwave
It sounds like your electronic board has malfunctioned. It may have to be replaced, sometime it is cheaper to buy a new oven. Technician's fees and parts may be more than it it worth.
Dec 25, 2007 | Sharp R-402J Microwave Oven
Sharp R-9H56 Microwave convection oven
I have this model. Press clear then press Auto/Clock. Enter in the time eg 700 then press Auto/Clock again. The time should now be set
Jun 08, 2007 | Sharp R-1872 Convection/Microwave Oven
Westinghouse WST3504 Microwave Oven Logo
85 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Jaime Hernandez
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
