Question about Quartet gbc Shredmaster 5550X Confetti-Cut Shredder
Shredder does not shut off
After shredding papers, the shredder continues to run until the middle button is pressed. The power light (first light) keeps blinking until it is turned off.
  • 30 Answers
In my experience, there are three possible reasons for this problem. The first, and cheapest to fix is a scrap of paper lodged on the sensor that turns on the drive. You can take a flashlight and look down the throat of the shredder and see if there is any debris just above the cutting blades. MAKE SURE THAT THE UNIT IS UNPLUGGED! Take a small utinsel like a letter opener and remove the scrap from the throat of the shredder. There is also the possibility that there is dust on the sensor. This takes a bit more finesse. A small brush, like a skinny paint brush, like kids use for painting with water colors, will brush the dust off the sensor and it should work normally again. The other two reasons are going to require the services of a qualified technician, as either the sensor itself is bad or the control board that the sensor connects with are bad. It will cost you unless you are still covered by warranty. Let me know if this helps. Aloha, Bill Monroe
Posted on Sep 29, 2007
SOURCE:
The shredder doesn't automatically shred anymore. How do I set it so the "eye" works and it shreds automatically without me holding down the button?
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Sep 04, 2013 | Quartet gbc 5550X Shredder
I have an Ativia 6000 shredder. The red light comes on and the shredder stops, after only shredding a few papers..why?
If place too many pages in the shredder the motor will be overworked and it will overheat and shut down until it has cooled down. Try shredding fewer pages at a time.
Jul 03, 2012 | Computers & Internet
My shredder stopped working in the middle of a shred. I have cleaned all shredding from it, but it still refuses to run. Is there a thermo cut off switch, and if so, where?
  • Shut off the shredder. Unplug it and let in cool down for up to one hour. This will work if the shredder has stopped due to excessive use.
  • 2
    Check to see if the shredder is jammed. This is the most common cause of shredder problems. Click the power switch to reverse, which should clear a minor jam. If not, set the shredder to auto, and then to reverse again until the jam clears.
  • 3
    Clear extremely stubborn paper jams by grabbing the stuck paper and gently pulling it out. If smaller pieces of paper cause the jam, shut off the shredder and unplug it. When it cools down, carefully use a pair of tweezers to remove the paper bits.
  • 4
    Determine if the power supply to the shredder is working properly. If the power supply is cold, use an alternative source of electricity for your shredder. If it is warm, there may be a problem with the shredder itself. Call your office machine repair shop or the shredder manufacturer for assistance.
  • 5
    Sharpen or oil the blades. Shredder blades need to be oiled on a regular basis to keep your machine in proper working order. Get oil made specifically for shredder blades from an office supply store.
  • Jan 02, 2011 | Office Equipment & Supplies
    STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
    can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
    Dec 16, 2010 | Office Equipment & Supplies
    My shredder won't continuously shred a piece of paper. I have to reverse it then turn it on again multiple times to shred just one piece of paper. Can I fix this?
    If it is a x-cut shredder try oiling ( with a lightweight shredder oil ) onto a sheet of paper then shredding the sheet of paper to get the oil down into the cutting teeth....also try cleaning the "eyes" which are in the middle were you insert the paper..( they may be dirty.)
    Nov 19, 2009 | Office Equipment & Supplies
    Tech Solutions shredder Only powers in reverse w/ green light
    Their are sensors on top and bottom of cutter asm. Good chance one or more are dirty, blocked with paper shreds or just bad. Clean with compressed air and lightly moistened cotton swab.
    I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
    Jun 01, 2009 | Tech Solution TS-8000 Cross-Cut Shredder
    Royal 150MX shredder won't auto shut off. When powered on, always runs until powered off, even after all paper is shredded. Is this also a reset problem or something fouling a switch?
    Prob could be the "eyes" in the middle where you put the paper in. They just might need cleaning with a soft cloth( unplug machine first.) If that dos'nt fix it the eyes could be faulty or the pcb could be faulty....give Royal a call at 1-800-524-0799 for parts and prices.
    Mar 07, 2009 | Royal 150MX Cross-Cut Shredder
    Champion shredder WQ120D will not shut down after shredding but continues to run . must move to center position to shut down
    If you look at the blades, some are likely bent (probably the middle ones) causing the machine to not drop the clippings which makes it think that there's paper to be shredded. It's a common problem with this shredder and there's no fixing it because the company doesn't offer replacement parts. The shredder is an overpriced piece of junk. I bought mine at Walmart but our local store doesn't even carry them anymore because of all of the returns they've had.
    Jan 20, 2009 | Office Equipment & Supplies
    PowerShred C-220 will not shred automatically
    OK lets try.
    You likely have a photo sensor that detects the paper and it is dirty.
    It is likely covered with paper dust (hopefully only on the outside)
    Locate the sensor and wipe it off or just wipe the entire throat area.
    WITH MACHINE OFF
    Hope this helps
    Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
    Quartet gbc Shredmaster 5550X Confetti-Cut Shredder Logo
    296 people viewed this question
    Top Quartet gbc Office Equipment & Supplies Experts
    WTF Chuck.....
    WTF Chuck.....
    Pie-man
    Pie-man
    Bill Boyd
    Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
