Question about Archos Gmini XS 202s (20 GB) MP3 Player
Gmini XS 202s wont turn on properly....
I hold down the power button and the lights and screeen show the loading/welcome screen that it normally does when it powers up. this screen then sticks for slightly longer thean normal and then the power cuts out. if i hold down the power button for longer then it stays on this screen until i let go. I also have exactly the same problem with an old Archos Gmini 400 multimedia player. Any ideas??? Many thanks
  • the_waggster Oct 29, 2007
    yeah i wouldnt mind selling it to you if you want it.  how du wanna go about doing it??  price??
I heard of that problem, it could be your charger circuit and it could be your battery. There's a interesting forum post on this at www.newmp3technology.com: http://www.newmp3technology.com/forum/viewtopic.php?t=700
But here's something else: I'll buy your xs202s if you want.. :)
For a reasonable defect-price.
I have one but the display is broken.
Had no luck trying to find that obscure 2" 128x128 backlit greyscale korean display in the IC-market here in Europe.
Posted on Oct 29, 2007
SOURCE:
I replaced my lamp on a panasonic pt-lm2e with a new lamp same model,once i power it on it shuts down after 2 seconds,why
google ur model and how to reset the unit. normally
its holding down a couple of buttons. good luck
Sep 19, 2014 | Panasonic Televison & Video
Where can I get a new display as I have broken it ?
Contact Archos, the manufacturer:
http://www.archos.com/
Nov 23, 2009 | Archos Gmini XS 202s (20 GB) MP3 Player
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
All i get is the welcome screen and no light by the standby button. it has power
If normal operation has the welcome screen dissapear after a few seconds followed by working properly, it appears the internal software is corrupt or buggy.  Try a power drain:
1. Unplug the product's power cable so the device is not grounded to the house. 2. Press and HOLD the product's own power button for 1 minute to drain the capacitors. 3. Plug the product back into a wall outlet and try to turn it on.
Note: This procedure works with battery operated devices as well so remove the batteries and hold down it's power button.  Electricity can remain in capacitors and on circuit boards enough to prevent normal functionality. By clearing the residue electricity, your product will have a fresh start and many times this will resolve a buggy or non-responsive device that appears to be dead.
If this doesn't resolve it, the Toshiba will require service for defective software.
Mar 26, 2009 | Toshiba SD-H400
It's not working!
Hold the X button for 10 seconds and it should re-boot itself.
Aug 08, 2007 | Archos Gmini XS 100 MP3 Player
DEVICE HAS'' READ ACCESS ERROR-CANNOT READ FROM HARD DISK''
If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. If not you could try formatting it using a DOS prompt.
May 22, 2007 | Archos Gmini XS 100 MP3 Player
Klackitey Klack
If the drive is ticking, it suggests the actual HDD is dying. You can try the following to see if you can fix any disc errors through your PC, however if your PC does not recognise a drive has been attached you may be unable to do anything other than have it repaired elsewhere. If you have problems with the file system on your Gmini you can try to fix it using the DOS utility, check disk (chkdsk). Do the following; ? Make sure external AC adapter is powering the Gmini. ? Quit all running applications. ? Properly connect the Gmini to your computer ? Wait patiently (up to 5 minutes) for Windows XP to show the local drive as mounted. ? Open a DOS window. Programs > Accessories > Command Prompt. ? At the prompt, type chkdsk e: /f. Use e: or f: or whatever drive letter is representing your Gmini. The /f argument tells the program to automatically fix errors. ? Be patient, this may take a while. ? When it is finished, exit the DOS Window and properly disconnect the Gmini from your computer. Try using the device now and see if makes any difference. This method should help to fix any disc errors that have occurred within the FAT and help your PC recognise it again. If you have more problems, try formatting it using a DOS prompt. You MUST make sure NOTHING is trying to access the disc before you can format it - this includes windows explorer.
Apr 04, 2007 | Archos Gmini XS 100 MP3 Player
Archos gmini xs 100
New hard drive. Mine died, too. klick-klack, rrr, klick-klack... end.
Dec 29, 2006 | Archos Gmini XS 100 MP3 Player
Archos Gmini XS 202s (20 GB) MP3 Player Logo
172 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
