Question about KitchenAid KGRS807SSS Gas Kitchen Range
We just purchased the KGRS807SSS gas kitchen range
We noticed that when we use the oven for baking, a fan keeps the front top area cool.When we turn off the oven, the fan stops running and the area where the knobs and time are, gets very hot.It gets so hot that it almost burns your hand. We sent the 1st oven back and asked for another oven. The new oven does the same thing and gets very hot. The only way we can keep it cool is to leave the oven door open after we are finished using the oven. Is this normal??We are afraid that the heat will hurt the componets such as the clock. our previous oven had to be replaced because of this type of problem. Please help us and let us know if the heating problem is normal.
  • Anonymous Mar 25, 2014
    Oven starts to heat up and then automatically shuts off. The hot area indicator light no longer works.
  • 473 Answers
This is normal. Typically the vent from the oven will come up between the cooktop and the control panel.
Posted on Oct 05, 2007
Fes367dsa fan runs while baking but it is not a convection oven
Chris Lindstrom,
I understand that you have a fan running while you are baking. This is a totally normal function of your applliance. A cooling fan may automatically turn on and off to cool internal parts. It is normal, and the fan may continue to run even after oven is turned off.
-Best Regards-
Jan 15, 2014 | Frigidaire FES367 Electric Kitchen Range
When I turn the oven on, there is a fan that comes on that sounds very noisy. It sounds like a vibration in the cooling fan. I'm wondering if simply swapping out the blower would take care of the noise? ...
yes this will work for you, but before you change out the fan motor make certain the fan blades are unobstructed and not rubbing against anything this can make quite a horrible noise as well.
best regards Falco
Nov 04, 2013 | KitchenAid KGRS807SSS Gas Kitchen Range
Im having a problem with getting my oven to heat....so its not baking or heating in any sense. I've continuously unplugged the stove and attempted to get it heated but it still never gets warm or anything....
Hello and sorry to hear about your problem.
It sounds like your oven glow rod, is defective. This is the electronic pilot lite for the unit.
I suggest you can in a service person. If you live in the Denver Co area, I can help you.
I have tried to help you. Please help me by Vote/Rate this response. Thanks and good luck.
cvbb
cvbcb
Dec 23, 2010 | KitchenAid KGRS807SSS Gas Kitchen Range
After baking and trying to set time bake a week ago, the range won't turn on at all. Nothing happens when we press bake, broil, convect bake, etc. The clock, lights, fan, timer and cook top still work.
the oven controller in the main service/selection panel has either a bad solder joint on the circuits or the start realy for the oven on the same circuit board is bad and you have to replace the whole panel you cannot just buy the relay
Jan 20, 2010 | Jenn-Air JDS9865BDP Stainless Steel Dual...
The f2 keeps beeping. How do I turn this off
"F2" on most GE ranges is caused by a fault in the oven temperature circuit. Depending on model, this could mean a defective oven temperature sensor, a stalled (or faulty cooling fan-if equipped), or a BAKE relay contact on the Electronic Range Control (ERC) board that has welded (shorted) together. The easiest thing to start with first is to UNPLUG the range and check your oven temperature sensor resistance. The following link explains:
http://www.fixya.com/support/r393313-checking_replacing_oven_probe
If you do not have a cooling fan on your model, more than likely you have a problem with the oven temperature sensor, or the ERC bake circuit. If the sensor checks good, your ERC needs replaced.
If you have questions, please let me know. I hope this helps you.
PS Unfortunately, when these error codes appear, they usually cannot be defeated. This is a safety feature that warns (or prevents) the consumer from using the appliance in a potentially unsafe condition.
Jun 10, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Replace oven UI -KitchenAid KGRS807SSS Gas Kitchen Range Problem
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
Oct 19, 2008 | KitchenAid KGRS807SSS Gas Kitchen Range
KitchenAid KGRS807SSS Gas Kitchen Range Logo
453 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
