Question about BenQ PB6110 Multimedia Projector
Problem in logic card of the projector
I m having the projector of the same modle and the logic card of the projector is faulty please suggest where would i get the service of the projector in Delhi
I have Benq PB6100 it is working but it not search for video signal and some of the buttons is not working is there is any solutions?
Posted on Dec 11, 2007
    Sergeant:
  • 274 Answers
BenQ has support in India: http://www.benq.co.in/ India India Customer Help Desk 1800-22-0808 (Mon to Fri 0830-1730hrs) Service ID service-In@BenQ.com Sales ID SalesEnquiryIn@BenQ.com (Lunch time : 1:00-2:00hrs PM) But this model is out of production so you may have trouble getting parts.
Posted on Oct 01, 2007
NEC LCD1760V shuts power down after 3seconds
Hi Ron usually power down issues are caused by faulty power supplies especially if the projector looses power completely however the logic board could be protecting itself if it detects a fault such as a fan not working either way it is not recommended that you try to fix it yourself unless you know what you are doing, but it may be worth removing the cover and checking that the fans are working and connected properly, occasionally the lamp can be at fault especially if it has been used for many hours if the projector tries to power up and you see light through the lens and then it looses power its probably the psu at fault, if it powers up then goes into standby of fault then its most likely a logic issue. I hope this helps Regards Ant
Nov 30, 2011 | NEC Office Equipment & Supplies
What is the probem if Lamp/cover alarm come after a minute in sony projector
Possible that the filter is clogged and is not cooling, it can be a faulty limit switch of the lamp cover or finally and error in the logic control.
You need to check the micro limit switch that is at the base of the lamp cover, check if this is closing and if the switch is showing contact- use a multimeter to confirm.
Oct 19, 2011 | Office Equipment & Supplies
VIEWSONIC PJD5111 SHOWS VERTICAL LINES
Hi... Projector show vertical lines... Issue in your logic board filter's missing on logic input board check for fail signal on video input logic board,,, check input connector for broken pin inside connector... also check capacitor & resistance arround video logic processor, possibility of over heat conponent
Oct 25, 2010 | ViewSonic PJD5111 Projector
We have a Sony Bravia 40'' LCD that the screen went white and then black and won't come back on. The power button comes on but no picture. Just bought the TV in Nov 2009
the most likely the t-connector board became unplugged or failed completely (sits right behind the screen modual at the top&center) or.. the logic board has went kaput on ya...ontop of that, you are dealing with the notorious sony. try and get a replacement if under warranty. do not settle for thier refurbishing.
repairing these things i can tell you , it could be anything from a bad connection or ring cracks to completely failed parts. but only if i was in it would i know for sure. but the symptoms suggest t-connector or the logic board.
Feb 15, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
How I can solve hummer voltage 1
You must check the adjustment of your AVR and the Machine Voltage Switch.
Feb 15, 2010 | TallyGenicom 6306 Matrix Printer
How to get the logic card of 5610 and the cost of
purchased the HP 5610 Office jet Printer and the warranty is over now. I got the problem and the loca dealer has refused to repair the same due to non availability of logic card. Please suggest me how to get the logic card of 5610 and the cost of logic card. I belogns to Kurukshetra(Haryana). Pl. suggest me.
Dec 10, 2009 | HP Officejet 5610 All-In-One InkJet...
Memory card parameter error is finding in my memory card.
The memory card may have developed an error in card logic format.
Save all data from memory card into computer, then format the card clicking right button of mouse on card (removable disk) on computer and select format option.
If you still get the error some time after formatting the card, then card is faulty, get a refund or replacement.
If I was in your shoes I would ask a replacement immediately, if card is really faulty it won't warn you before losing all your data.
Aug 15, 2008 | Panasonic Lumix DMC-FX8 Digital Camera
Faulty projector
Before a modern projector will strike the lamp it will check if the lamp is good either by remembering how many hours the lamp has been used or by measuring it with its own internal circuitry. if the test fails it will not strike the lamp because starting a bad lamp can potentially damage the projector and surrounding property.  Is the lamp old? Does it need to be replaced? if not then it may be a logic board and now requires service from a trained repair technician that has access to the parts it may need.
May 17, 2008 | Dell 2100MP Multimedia Projector
BenQ PB6110 Multimedia Projector Logo
170 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
