Question about Vector 995 Radar Detector
Internal Speaker type/rating?
Does anyone have any idea what the specs of the replacement speaker should be? How many Ohms/watts? I opened up the detector and it is a small plastic-like speaker labeled "AS2832-LW56 PUI China". I'd rather find the right type of speaker for about $1.00 instead of paying Beltronics $38.00 to ship me the same crappy speaker that broke in the first place.
  • sschellato Sep 28, 2007
    What does "ic" stand for?? Please clarify.
    Thanks
  • Anonymous Apr 09, 2008
    I have the same model and everything, did you end up fixing your and if so can you please show me how, I'm with you I don't want to send it to get repair for $ 50.00.
    thanks
  • 134 Answers
The speaker is a 28mm diameter 32 Ohm speaker. Bel/Escort now use a newer custom PUI manufactured "high temp" speaker which resolves issues of the speaker blowing out due to high temperatures. Contact Bel/Escort using their online chat feature on their web sites. Likely they will send you a replacement speaker for a cheap price which you can solder in yourself (assuming that your RD is out of warranty).
Posted on Apr 20, 2009
If it helps I called Belltronics at 866-468-0322 and asked how to get a new speaker. The lady asked if I was handy enough to fix it myself and I told her yes. She then sent me one for free.
Posted on Nov 05, 2007
The speaker is 32 ohm and .2 watts.
Posted on Jan 29, 2008
Look what is driving the speaker,ic that is and that might give you clue, by looking up the spec for the ic.
Posted on Sep 28, 2007
I got 2 10in kicker comps and the rms on them each is 150 watts and can i hook them up to a 1000 watt sony xplod 2 channel amp and do i use both channel or just one or bridge them
1st thing is amps outputs have to be properly "loaded" this value is given in "ohms" if your amp says minimum speaker "loading" impedance is 4 ohms ( I suspect it does) then you may load that 1 channel down to only 4 ohms or amp will be damaged , most speakers are rated in ohm's Impedance (look for Greek symbol for omega) look for its rating somewhere on it doing the electrical formula math if you connect two 4 ohm speakers in parallel to one channel ( +=+ / -/- ) this divides down to 2 ohms (not good) but if you take same speakers and connect in series together (+to-/+to-) this gives you eight ohms (better) , the watts rating is a figure for you to determine the amount of power the speakers will take before failure , hence just because you connect 200 watt speakers to a 2000 watt amp is no indication that speaker will take all 2000 watts ( it will fail long before that point ) watts do ADD together like the above example two 4 ohm 250 watt speakers connected to one channel of amp in series will look like ONE 8 ohm 500 watt speaker to amp of course over 16 ohms load speaker volume will greatly diminish and amps have max impedance loads for them as well although there not often published
this is why I love the old TUBE!!! amps they load all the way down to 2 ohms and go up as far as 32 ohms load with no problems , they sound better as well across the board as well
Sep 10, 2015 | Sony Car Audio & Video
What is the wattage breakdown for each speaker on my pair of Pioneer CS-N575 3 way speaker towers (I know the total max power combined output is 150 Watts)?
It's the woofer that will use almost all from this 150 W so if you replace woofer take one of 8 ohm which can handle 150 W and you done
Jul 15, 2014 | Pioneer Audio Players & Recorders
What size amp will i need to run 2 PV115 speakers
An amp with 700 watts power per channel at 4 ohms as recommended in the spec sheet, depending on the crest factor or your program material you may want to go with the continious power rating of the speaker.
Mar 14, 2013 | Peavey PV115 2-Way Speaker
What amp for a Pioneer TS-W304C 12 inch sub
You seem to be looking for an amp made for car audio. There are many brands, but I going to give you the specs for your particular speaker which will help in choosing, not a specific name brand amp, but at least one with the proper power outputs/requirements.
Your speaker, based on the model number you provided, is rated at 4 ohms .Power handling range is 50-300 watts. And a peak of 600watts. That does not mean start cranking 600watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms.
Hope these specs help you in choosing an amp.
Jan 07, 2013 | Car Audio & Video
What amp for a Pioneer TS-W304C 10 inch
Wow, i just answered a similar question so, pretty much the same answer.......
Your speaker, based on the model number you provided, is rated at 4 ohms .Nominal power handling range is 300 watts. And a peak of 600watts. That does not mean start cranking 600 watts thru the speaker, it will blow. I suggest you acquire a single (mono) channel amp that provides 350-400 watts at 4 ohms. Leaves you a little headroom on the amp, but use caution.
Jan 05, 2013 | Pioneer TS-W304C Car Subwoofer
What is the actual watts per channel @ 8-ohms and 4-ohms on the Behringer PMP3000?
Those specs would be right - I have this same board but the amp was fried by a previous owner. I pulled the amp board out and tossed it and use the mixer now to drive an external amp. Great board. This amp is rated at 1200W "peak", bridged into an 8ohm load. That would equate to about 900W RMS bridged into 8ohm or 450 per side into 4ohm loads per side. You can't daisy chain all 4 speakers....impedance would be too low. You can run two of your 8ohm speakers per side - that results in a 4ohm load per side for the amp. That would give you amp delivery of 450W per side. Your speakers are rated to handle more than that so you're fine. For the record.....you could run one speaker per side no problem....just lower power output.
Aug 16, 2012 | Behringer Pmp3000 16 Channel Audio Mixer
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
Can i add another speaker to it
The specs do NOT show an auxilary speaker jack so the answer to your question is that you cannot add another speaker.
Mar 08, 2011 | Pyramid GA610 600 Watts Dual Channel...
I have blown-up my JBL rear woofer 86160 - 26W and 3.7 OHM. I am having difficulty finding the exact same woofer again and hence wanted to know is there a replacement i can use. I understand the meaning of...
I just replaced my blown sub in my Avalon xls with a Kicker 07C84 and it works great. For the same price of a repair kit, you can just buy this new speaker. Why go through the hassle of repairing a 9 year old speaker. This speaker fits into the same cutout of the old speaker. All I did was splice the red and black wires within the factory plastic housing so I could still use the factory connector.
Jun 13, 2009 | 2001 Toyota Avalon
I found this amp and I can't seem to figure out what the wattage is?
You are probably aware on how to use these output figures, but I'll write a quick explanation on the specifications for future readers anyways :)
The concpet CC-452 amplifier has the following power output specifications:
Calculated at 14.5 volts DC;
At 4 ohms per channel - 45 watts x 2 (RMS)
At 2 ohms per channel - 70 watts x 2 (RMS)
At 4 ohms bridged - 150 watts x 1 (RMS)
This means that your amplifier would provide 45 watts of power each for your front speakers, which are normally a 4 ohm load per side (45 watts for left, 45 watts for right), that's unless they are one of those exotic higher end brands (eg: Boston Z6s which are 3 ohms). Rarely, you will find speakers that are rated at 2 ohms per side, but in this instance the amplifier will provide 70 watts of power into each speaker. On your speaker specifications, you will find a value termed "nominal impedance" which will give you the ohm rating of the speakers being used..
On the other hand, if you "bridge" both channels into a single channel (using a diagram often marked on the speaker terminals of the amp), you could then provide 150 watts into a subwoofer (providing it was a 4 ohm woofer).
It's not recommended to use this amp bridged under 4 ohms..
Some subwoofers may be lower than 4 ohms, and you will not be able to use this amplifier for these types of speakers without risking amplifier failure. Also, some subwoofers may have 2 seperate voice coils, and you will have to use both channels of the amplifier seperately (not bridged) in order to correctly connect this type of speaker for use.
Oct 28, 2008 | Concept CC-452 Car Audio Amplifier
Vector 995 Radar Detector Logo
1,184 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
Steve
Jerry Greenberg
Jerry Greenberg
David Payne
David Payne
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
