Question about Olympus Stylus 710 Digital Camera
Blue screen and error message
When I turn my camera on, the retractable lens seems to have a hard time retracting thus producing a blurred image on the screen even if you press the shutter half-way for its auto-focus still the image being focused is blurred then after a few seconds the screen turns blue with an error message code like so.... D : 5f08 5e02 any solution would highly be taken in appreciation
  • wm2313 Feb 08, 2008
    same exact problem and it happened right after i took a picture.
  • machang Feb 08, 2008
    i have the same problem. would appreciate if i can referred to any repair center here in Manila.
    Genius:
  • 2,985 Answers
No solution you can make- The motor mechanism is shot Depending on how long you have had the camera you may get it replaced or a repair price quoted. The repair price will be horrific buy the next camera.
Posted on Sep 28, 2007
SOURCE:
System error focus
you hve probably damaged the lens unit. impact while the unit was extended? the auto power off will retract the lens thus damaging the little plastic gears in the lens unit. you may need to replace the lens unit
Dec 18, 2013 | Panasonic Lumix Dmc-fh1 12 1 Mp Digital...
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
C875 lens won't retract
Camera (with new rechargable batteries) won't let the lens come out or if it does it instantly retracts.
Nov 14, 2008 | Kodak EasyShare C875 Digital Camera
Olympus u 700
In on postion in camera mode,the lens seems to move in and out,blurring the image and then stops with this message on screen. D: 5f O8 5eO2
Jun 26, 2008 | Olympus Stylus 710 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Bonnie
I was getting the Lens Error message on my A730, even though my lens seemed to be working fine. I'd had the camera in my pocket, and apparently it tried to open but jammed. But it seemed to be OK except for the cursed Lens Error message when I'd power it on. The way I found to fix it is press and hold the "func/OK" button on the back, then turn the camera on. Now it's working again. Note that this may not work for you if your lens is actually screwed up. Mine wasn't.
Dec 12, 2007 | Cameras
Olympus Stylus 710 Digital Camera Logo
284 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
