Ibico Binding Machine User Manual/Instructions
Howdy! We bought the Ibico Ibimaster 400 Manual Binding Machine (comb & wire) and were unfortunately given the wrong manual! Now we can't figure out how to use it for wire binding (eg for calendars). I have been searching high and low for Ibico support and product info to no avail so if you could provide a link with the user manual to download, we would be truly grateful! Ta, Alex
  • 7 more comments
  • sharppa Nov 26, 2007
    We have a Manual Ibico Wire Binding machine Karo-40 and don't know how to use it. I have tried to find info on web but to no avail
  • mcsween Nov 26, 2007
    I've just started working in a non-profit office with an Ibico Hi Tech model wire/comb binder. They can't get the wire apparently, so we're using plastic combs, fine... but having to thread the combs through the punched holes by hand!!! I'd like to fix it (in the interests of sanity). There's a place in front to open the comb but the relevant handle at the back won't budge, and the plate underneath that should move, seems stuck. Can I undo the screws and try to free it? Can't find a manual that would let me try to repair it rather than call out repairman. Can anyone help?
  • Kriswil Dec 20, 2007
    I bought a ibico binding machine but it didn't come with any instructions and I need to know how to use it?
  • CharlesR Feb 13, 2008
    I just purchased an IBICO Ibimaster 400 comb and wire binder from a failing business. It came with no manual. I figured out the plastic comb binding, but not the wire bindeing portion. Also, I would like to know the maintenance proceedures that only a manual could tell you.
    Thank you,
    Charl R.
  • Jerry Quinn Apr 30, 2008
    I found the IbiMaster 400 manual!!! The key was finding out that Ibico was sold to General Binding Corp. (GBC). I went to the GBC web site and it linked me to Acco. I called Acco and they promptly sent me an old, scanned PDF of the manual. The very helpful POC at Acco was:
    [email protected]
    Jerry Quinn
  • schultzj Jun 19, 2008
    how do you use it? we found it at work and have no manual and no clue how it works.
  • Anonymous Aug 19, 2008
    hi. found 400e operator manual at:http://www.acco.co.uk/pdfs/1092.pdf
    found parts list at:http://images.mybinding.com/www.mybindin...
    luck mel
  • Nadiuska Sep 25, 2008
    I have the Manual for the ibimaster 400 but i cannot fit the wire binding to the holes it make, they just to do not much am using 3.1 wire - although mine has 34 instead of 21
  • Anonymous Mar 18, 2009
    cutters seem to be dull. It is making a rough cut . where cun i buy cutters for IBICO manual binding machine
[email protected]
Jerry Quinn
Posted on Apr 30, 2008
Does anyone have instructions for using the ibico hi tech binding system? I lost the instructions on how to attach the wire or combs to the papers. Thank you for your help
Posted on Mar 23, 2009
    New Friend:
Can't get the comb opener to open. Can it be adjusted?
Posted on Aug 24, 2010
To add to the above, this site has illustrations of various binders...
‘http://www.fixya.com/support/t209109_ibco_binding_machine_user_manual’
Posted on Mar 07, 2008
There are roll pins in the cutters that can shear if too much force is applied when trying to raise the cutters if the cutters are jammed. The easiest way to clear a jam is to remove the waste tray, turn the binder over and use a piece of wood to hit the cutters back. Nothing needs to be taken apart. Once they are no longer jammed and a cutter does not retract when the handle is raised, you have sheared a roll pin. Replacing a roll pin is not that difficult, but you better take some pictures as you start taking things apart so that you remember how everything goes back together...
Posted on Mar 06, 2008
    New Friend:
Graag zou ik de handleiding van de ibeco hi-tech wensen want ik heb die niet en weet niet hoe deze machine functioneert
Posted on Feb 15, 2010
SOURCE:
User Guide for the machine
i need clubpenguin unused membership
May 01, 2013 | Wilson Jones CB256 Comb Binding Machine
What types of binding machines are there?
There are 3 main types: comb binding machine, coil binding machine or wire binding machine
Jan 28, 2013 | Office Equipment & Supplies
Megabind 1 binding machine comb opener is stuck
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 10, 2012 | Akiles MegaBind 1 Plastic Comb Binding...
I have an Ibico ibimaster 400e Binder which is not punching out the holes correctly.
First, clear the waste tray of all hole punchings under the machine, and check the holes where the punchings feed from for any blockages. The worst thing is the clear plastic pages you use for covers, these can block up the holes. So you may need to pick them out of the holes using tweezers.
Then try again. If you have to punch clear covers, then try to do them with just a few pages on both sides so that the plastic sheet isn't the first thing the blades hit.
May 23, 2011 | Office Equipment & Supplies
Ibico binding machine
I have sold some Ibico machines, depends on the model some are only designed to punch a few sheets such as 6 to 10 booklets. Need the model.
Jun 24, 2008 | Office Equipment & Supplies
I need to downlaod ibimaster 400e user manuel
search at this site for the manual:
http://www.acco.co.uk/literature_download/
Jan 21, 2008 | Office Equipment & Supplies
Ibico 080s
ACCO Brands Corporation owns General Binding Corporation (GBC). GBC offers products under numerous brands, including Ibico. Ibico's owner's address appears to be in Switzerland
From GBC's sparse Ibico's homepage:
"Contact Us
Where can you buy Ibico Products, fill in your information and the products that you are interested in and we will send you information on the nearest Ibico dealer. "
I'd suggest just going to that page (link here) and filling out the contact info and including the specific information about the model found on this page (namely the product ID num)
.... i could be way off... but it is all i could find on google =)
Jan 04, 2008 | Office Equipment & Supplies
20,772 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
