Question about Samsung SGH-E900 Cellular Phone
Keypad buttons not working
Hi, once I have turned on phone, none of the keypad buttons work, tried cleaning etc, not worked, please help, bought it of ebay, no instructions.
Key pad not working
Posted on Apr 21, 2010
  • 452 Answers
There is some problem with the pad that is exactly below the keypad ,if even after cleaning that the problem has not been resolved so get it replaced from samsung care
Posted on Oct 22, 2007
Motorola karma. Only the red key works, none of the others is recognized. Took battery out, no help
Hi, most problem caused by keypad not functioning, is always water issues.
Unscrew the phone and clean up the keypad area. And your done.
After cleaning up the keypad,if it does not work, means that the problem is from the board of the phone.
There is an IC inside the phone that controls keypad function, when IC gets damaged, keypads will not function until it's replace.You will need to contact a skillfully personnel for help.
Oct 09, 2010 | Motorola Mobility Karma QA1 Cell Phone
Only One Button Works On My Motorola Razar
fone may need flashing or keypad changed
Aug 31, 2009 | Motorola Mobility RAZR V3
The soft keys(menu, contact, okay button, send,etc) doesn't work!
there is a ribbon cable inside the phone that tends to get loose, you can try reseating it, but be careful!
Jul 02, 2009 | Helio Ocean Cellular Phone
Can receive calls and texts but none of my buttons are working, I mean none. I can't answer calls or even turn on/off the phone. Could this be my battery is no good?
This usually means your keyboard is defective.
First try installing the OS on the phone either reinstall the old os or try and upgraded version.
A.) Remove the battery, Plug in( if keyboard still does not work try the following:
1.) Applications
2.) Options
3.) General settings
Note: your phone may have a different os than I pulled the above information from just try to get to general settings and then hit blackberry button for wipe handheld option. Don't forget to backup your contacts etc before doing this.
Depress the blackberry button (button with all the dots on it) then select wipe hand held. Be careful as this will erase possibly everything on the handheld
If none of the above work to get your keypad working it will need physical repair.
Jan 06, 2009 | RIM BlackBerry Pearl 8100
My Samsung G600 has stopped working
This would mean that at sometime your phone got wet by some form of liquid.I don't know if u could do this but the phone needs to be opened and your keypad needs to be lifted(the one on the pcb or main board) and cleaned thoroughly by a spirit solution that would evaporate and then'll have to clean the pcb side and the contacts on the actual keypad and that should do the trick hopefully.try not to disturb the adhesive on the keypad because you would need to reseat when u r finish cleaning. thanks !
sam !
May 28, 2008 | Cell Phones
take the phone to a mobile service center that fixes out-of -warranty phones and have them service the keyboard...this should fix the problem that you have
May 27, 2008 | Nokia 6133 Cellular Phone
Nokia 1100 keypad lock code
i have a nokia 1100 ,its keypad lock no not working / please advise me to unlock the keypad.....
May 03, 2008 | Nokia 1100
Keypad does not work
I had a common problem which none of my keys worked except the "off" key. I baked my phone in the oven on the lowest setting for 20-30 minutes and it works now. It is a humidity issue.
Mar 16, 2008 | Motorola Mobility RAZR V3
Motorola SLVR buttons do not work
I don't know but mine's doing the exact same thing. Mine also keeps the screen on almost all the time, sometimes it turns itself on and back off and back on for hours. Once every button EXCEPT the red button worked... and once only the top left button worked, so i could answer calls but couldn't hang up. My friends enjoyed messing with me for that one.
Dec 01, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
216 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
