Home | Ecoquest | Living Air Classic Air Purifier | Have a Living Air XL1...
Ecoquest Living Air Classic Air Purifier
Problem for Ecoquest Living Air Classic Air Purifier
Have a Living Air XL15 > everything works motor, fan, BUT .....
By dellitron on Apr 26, 2009
Have a Living Air > XL15 > everything works motor, fan, BUT ..... there is no clean smell coming from it - everything appears works .. but i can not smell the ION Clean Air ?
Best Solution
posted on Jul 02, 2009
Very Helpful)
dalegilchris
Rank: Apprentice
Rating: 100%, 2 votes
look through the front grill while its "on" you should see a glow from a neon lamp inside. If its not on chances are the circuit card is dead (should have about 350VDC plate voltage).
I have a used but good board if anyone needs one.
dale.gilchrist@gmail.com
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 12, 2009
Somewhat Helpful)
rib52
Rank: Apprentice
Rating: 75%, 1 votes
I have two Living Air XL 15 I have the same problem everything works will but not clean smell no Ions
Was this helpful?
Yes
No
Solution #3
posted on May 28, 2009
Somewhat Helpful)
dsharpy
Rank: Apprentice
Sometimes you have to really clean off the screens, this may even require using "scotch Bright" or even sandpaper.  You also have to be sure that there are not any cracks in the filter plates, this will allow arcing between the screens and may even ruin your ion generator. Give it a shot and if it does not work, send it back for repair, they are real good about fixing.
Was this helpful?
Yes
No
Popular Solutions for Ecoquest Living Air Classic
Questions and Unsolved Problems for Ecoquest Living Air Classic
Do you recommend Ecoquest Living Air Classic Air Purifier?
Answer
Answer
no high voltage to grid after 5 minutes operation
Answer
Appears that the high volatge supply has failed. Neither lamp (inside) is illuminated consiquentlky... (More)
Answer
the ozone only comes on at the highest setting. It is to strong to have it on that level. What is... (More)
Answer
Not producing ozone, wire on little round sensor is broken on the small silicned in circuit board... (More)
Answer
The internal light is on but the machine is not cleaning the air. Just blowing the air around.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ecoquest Living Air Classic...:
Top Air Purifier Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Purifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
