-   Try to power tv on and it sounds like it is powering on but the red temp and lamp lights just blink and tv won't come on-   Guest
Nov 15, 2008
-   popping noise & screen went black. then red light starting blinking-   Guest
Apr 11, 2008
-   Sony KDL 40V3000, purchased Dec 26 2007 happened twice now, Approximately every 6 weeks when attempting to power on the TV there is a slight flicker and then screen goes black and the standby light flashes twice continually. For the short term, simply unplug the tv for approx 1 hour, could be less but didn't want to take a chance. Apparently a high current situation trips a protector on one of the boards, this protection will reset but only if unplugged. if you leave it plugged in it does not reset.
After an hour, plug it back in and enjoy-   wally9966
Mar 07, 2008
-   same here. popping noise and then tv screen went black and into stand by mode (with red blinking light)-   omgsony
Feb 11, 2008
-   lamp light is blinking and tv will not come on-   Guest
Sharp Aquios 42" lcd. Wii remote incident. No picture, tried unplugging 5+ minutes for reset,...
(More)
Sharp Aquios 42" lcd. Wii remote incident. No picture, tried unplugging 5+ minutes for reset, no luck. Currently 2 lights flash followed by 1 light flash at bottom center of tv. Any advice?
when i turn on my tv i get pink dots all over the screne. when i turn it off and back on again the...
(More)
when i turn on my tv i get pink dots all over the screne. when i turn it off and back on again the pixels go away.
Panasonic TC22LT1 picture goes away after a few minutes. At first it seemed I could wiggle the coax...
(More)
Panasonic TC22LT1 picture goes away after a few minutes. At first it seemed I could wiggle the coax cable connection at the back of the tv and it would re appear, but it now stays off all the time.
I am having the same problem the picture will not show. the only thing working is the blinking red light.
Comment by Guest, posted on Jan 03, 2008
en trying to turn our TV on either by the on/off button or remote, it sounds like it's coming on and then goes right...
Comment by Guest, posted on Jan 01, 2008
50" sony wega... heard a pop noise in back of tv. picture went black. first a blinking green light and a short buzzing noise once or twice, then a blinking red light. what is this ?
Comment by Guest, posted on Dec 25, 2007
sony model KF-42WE610 - power light comes on and a clicking noise can be heard in back of in tv. No picture and after a few seconds power goes off. I found the source of the noise on what looks to me like a curiut board and could see it flashing. I have tried to look up a part number on the internet and am having no luck.
I had the same problem with the standby light blinking and the TV would go blank...eventually the red LAMP light turned on. Is this an easy fix or do I need to get a TV repairman and spend hundreds of dollars ??
Comment by Guest, posted on Dec 17, 2007
the stdby light had a weak rapid blink and wont come on
