Question about Epson Stylus R265 InkJet Photo Printer
No ink monitor
I am using an epson r265 and my little printer has disappeared from my taskbar at the bottom of the screen , i have followed epsons advice and gone into maintenance but my monitor preference button isnt lit so i cant add the icon to the taskbar. it still prints ok but ive got no ink monitor and when the ink is empty i have to take it all out and load it into my other printer that is on my sons laptop just to find out which ink cartridge is empty , how do i get my little icon back
  • julieanne798 Sep 29, 2007
    done that and it still isnt there
  • 2,985 Answers
Re load the software.
Posted on Sep 28, 2007
  • john ash
    john ash Sep 30, 2007
    But not completely it seems.
    Go to Start/printers and and Faxes and delete the printer icon.
    now go to Programs and right click on each Epson printer software icon- if it says remove -do from there.
    Now go to Start/Control Panel/Add-Remove software
    and look for any Epson Printer Icon remaining
    click on delete.
    Now reboot the computer.
    Ensure you are OFF line
    Disable any AntiVirus software
    Run the software disk again
    Follow the prompts exactly.
    Do bear in mind the ink monitor is a fudge based on the number of sheets passed, to tell you to buy another cartridge- it does not tell you the ink level - it is not possible so to do
    There is also a useful utility that will reset counters to individual head cleans and all sorts of other useful stuff - download this and when installed right click on the task bar icon to see what it can do.
    Another useful site is
    and then type in your printer model in the field.
Change cartridge before its finished on epson stylus sx100
  1. Do one of the following:
    • Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Then click the Maintenance tab.
    • Macintosh: Open the Applications folder, open the EPSON Printer Utility 2, select CX7400 Series, and click OK
  2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Sep 08, 2014 | Epson Stylus Office Equipment & Supplies
My Epson Stylus Photo R265 is not allowing IJT Direct compatible ink cassettes to be used - they load into the printer OK. What can I do to make them work?
The compatable inks you use will depend on how old your printer is
Epson change their printer every few months changing the chips so if you have a very early printer you need the earlier chipped compatables
Feb 21, 2010 | Epson Stylus R265 InkJet Photo Printer
How do I know WHICH of the ink cartridges is out?
I found this on the Epson Web Site. If you find this information helpful, pls rate me.
You can download the Reference Guide with pictures and all.
You can check the amount of ink remaining in the ink cartridges using EPSON Status Monitor 3 or the progress meter. Refer to the sections below for details.
EPSON Status Monitor 3 Access EPSON Status Monitor 3 in one of the following ways.
  • Double-click the printer-shaped shortcut icon on your Windows taskbar. To add a shortcut icon to the taskbar, see the section below.
    font26.gif See Monitoring Preferences
  • Open the printer software, click the Maintenance tab, then click the EPSON Status Monitor 3 button.
A graphic displays the remaining amount of ink.
If any of the ink cartridges installed in the printer is broken, incompatible with the printer model, or improperly installed, EPSON Status Monitor 3 will not display an accurate calculation for the amount of ink remaining in any of the ink cartridges. Be sure to replace or reinstall any ink cartridge indicated by EPSON Status Monitor 3.
Pls rate me. Thanks and Good Luck.....
Feb 09, 2010 | Epson Stylus Photo R220 InkJet Printer
Change ink caryridge
Install the EPSON driver software on the PC, connect the printer and the EPSON status monitor (Little printer icon on the taskbar) will show you howto replace the cartridges on your model.
Oct 28, 2009 | Epson Office Equipment & Supplies
2 red lights are flashing on my printer epson R265(END OF LIFE TIME SERVICE)
U can find resetter (SSC Utility or R265 Adjusment) at Reset the waste ink counter.Good luck.
May 29, 2009 | Epson Stylus R265 InkJet Photo Printer
Epson R265 Ink pad full
I have problem with r265 Epson. I installed new ink cartridge from epson but the printer could not recognize it. I installed SSC Service utilitry, but the programme could not recognize printer at this status. What can I do?
Nov 03, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson R265
Both redlights are flashing, and I need to change the waste ink any one help please
Apr 24, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson r265
download and install latest driver from Epson. Status monitor is in the driver. Check you have monitor ink setting active within driver.
Feb 18, 2008 | Epson Stylus R265 InkJet Photo Printer
This seems to be a "feature" of this printer with compatible cartridges although I'm sure it wouldn't be possible to get Epson to admit it. I have seen the same thing on other R265s and I haven't found a solution a yet. As far as I know, it doesn't affect printing - as long as there's actually ink in the cartridges it will print, despite what the Epson Status Monitor says, but YMMV.
Sep 20, 2007 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R265 InkJet Photo Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
